05 R1 fan not coming on until 115 degrees?
nitram38 - 9/4/10 at 08:48 PM
Anyone know the correct temp the fans should cut in?
Is my R1 temp sensor knackered?
adithorp - 9/4/10 at 08:52 PM
Normal cut in is 105c and out at 100c.
adrian
nitram38 - 9/4/10 at 08:56 PM
Temp sensor knackered?
Anyone got a spare I can buy?
[Edited on 9/4/2010 by nitram38]
adithorp - 9/4/10 at 09:03 PM
Looks likely to be the sender. Where are you reading the 115c from though? Is that accurate?
adrian
nitram38 - 9/4/10 at 09:06 PM
Im taking the reading with an spa capilary gauge just where the water leaves the head. The engine also starts to mis-behave and wants to stop. I'm sure the fans (ecu and original relay controlled) come in at 115
adithorp - 9/4/10 at 09:43 PM
Then I'd say it's the sender if you're happy the SPA is accurate. Infrared thermometer would confirm it.
Mine is happy to sit at the 105-100 range idling find. It does get easy to stall at that though so I tend to override earlier.
nitram38 - 9/4/10 at 09:53 PM
Where can I get a new water sensor?
adithorp - 9/4/10 at 10:16 PM
Yamaha?
stuart_g - 9/4/10 at 10:38 PM
definately 105 degrees for the fans to come on and off at 100 ish.
nitram38 - 24/4/10 at 11:58 AM
Changed the sensor and still the same cut in 115 degress. My infra red thermometer battery is shot. Typical when you want to use it!
I need to get a battery and recheck it!
I'm suspecting that the spa gauge is playing up.
Just got a new battery, gauge is reading 10 degrees over the actual water temp!
My fans work ok.
The engine was running a bit rough so I assumed the worst. Switched fuel maps as I suspect that my recent K'N filter change may have affected the idle.
I now have a spare temp sensor!
[Edited on 24/4/2010 by nitram38]
adithorp - 24/4/10 at 08:43 PM
I refer you to posts 4 and 6!
adrian
nitram38 - 24/4/10 at 09:17 PM
It was two things together that threw me. Gauge showing high temp and rough idling.
I think changing to a K'N plus the map you gave me meant I was running too rich. Changed the map back to my old one and its ok.
I need to get it on the RR myself!
