My car, now its work
fotograf2 - 28/1/17 at 02:19 PM
Pic on my car
[Edited on 28/1/17 by fotograf2]
slingshot2000 - 28/1/17 at 03:18 PM
Links / photographs are not working.
Nickp - 28/1/17 at 09:04 PM
That's an interesting variation on the '7' theme.
Can't decide if I like it or not, I think I kinda do. Certainly different, good work
SJ - 28/1/17 at 10:19 PM
The front and side look good but I'm not so keen on the rear end.
Looks like a great job though, showing a lot of skill.
ElmrPhD - 29/1/17 at 09:00 AM
Awesome (as we Americans tend to say.)
Clearly gonna turn heads and show that it's totally (again, American, sorry) of your own design and build-craft.
Ugg10 - 29/1/17 at 09:35 AM
Lot of work gone into that, well done, what is under the bonnet?
Reminds me of the Mirach.
swanny - 30/1/17 at 09:20 AM
reminds me a bit of a toniq too, which i always liked.
i quite like the back. it will look different once the lights and plates are on too
Ugg10 - 1/2/17 at 10:27 PM
Might want to check the IVA rules on mud guards, something about angles from the horizontal, rear ones may be close.
Nickp - 1/2/17 at 10:30 PM
He's in Sweden, just saying
Ugg10 - 1/2/17 at 10:54 PM
Doh!
Ratman - 6/2/17 at 01:34 AM
Nice work. I like the clean lines and black and silver. Is it running as you expected?
What are those lights? looks interesting. Please post more details.
[Edited on 6/2/17 by Ratman]
fotograf2 - 6/2/17 at 05:23 AM
I have not driven it much yet, but I think it goes well.
What is not so good is the clutch, so tight.
ReMan - 6/2/17 at 07:20 AM
When you say the clutch is tight, do you mean heavy, or that is difficult to operate smoothly, I guess it's a bike engine?
fotograf2 - 6/2/17 at 04:47 PM
Yes it is a BEC
I´mean as you says ReMan, it is difficult to operate smoothly.
Sorry my english is not so good but I do my best.
fotograf2 - 6/2/17 at 05:40 PM
Hi Ratman
Everything in one Stop/Tail & Indicator Led Lights
In Sweden a pair cost 80 pund
See the link: https://www.diodhuset.se/diod-xenon-till-lastbil-buss-maskin/bakljus-bromsljus-dimbakljus/kompletta-baklyktor/fiberoptisk-baklampa-12-24v
Ratman - 6/2/17 at 09:10 PM
I have a small bike engine in a go kart. If it isn't used for a long time the clutch plates stick together. After freeing up (just drive around with the clutch pedal down until they free up) the clutch is very savage. It just grabs. If I remember, when I am not using the kart, I tie the clutch pedal down so there is no pressure on the clutch plates. After this it is much better next time I use it. This might help you, but it's not so easy to do with a hydraulic clutch.
I like the light. Thanks for the detail.
I found something similar on ebay ... 8 034 Universal Motorcycle Flexible Light Strip Tail Brake Stop Turn Signal 48 LED
wow ... and here for US$2.39 https://www.aliexpress.com/item/48-Leds-LED-Motorcycle-Brake-Turn-Signal-Light-Strip-License-Plate-Light-Flashing-Tail-Stop-Lights/32694801873.html?sp m=2114.10010108.100009.2.30aFLT&scm=1007.13482.37805.0&pvid=89f69a9c-c909-42ff-8c98-79bea75af5b9&tpp=1
not sure if the same thing. No.. I see these are LED and your's are xenon so very bright !
ReMan - 6/2/17 at 09:38 PM
Originally posted by fotograf2
Yes it is a BEC
b
Better than my (any other language) !
The clutch will take some getting used to with practice.
But it may also need the pivot/cable attachment point at the pedal or engine end changing to reduce the ratio for better control
