Heavy steering
madteg - 10/10/11 at 09:23 PM
Have changed my wishbones and ended up with heavy steering, got any ideas.
rodgling - 10/10/11 at 09:36 PM
Stiff ball joints? I replaced two of mine recently (the boots were split) and the steering improved significantly - it's better now than it's ever been.
Are you sure you got the bones the right way round? Wrong way would screw up caster and could make steering very heavy.
[Edited on 10/10/11 by rodgling]
mark chandler - 10/10/11 at 10:00 PM
If the caster is more than 7 degrees then steering will centre quickly and be heavy to drive, maybe you wishbones have changed this geometry, if so it will feel different.
Regards Mark
mad-butcher - 11/10/11 at 06:32 AM
I have a similar problem http://www.locostbuilders.co.uk/forum/3/viewthread.php?tid=161150
RazMan - 11/10/11 at 06:57 AM
Regards Mark
My thoughts too - different bones could mean a totally different geometry
