Who sells steel mushrooms not offset
Daf - 5/11/17 at 07:12 PM
As per the title really, I'm using sierra front hubs and I need them to be steel as I have my wingstays welded to them and I want ones that are not offset.
Typically - I can find offset steel ones, and centred aluminium ones!
nick205 - 6/11/17 at 08:57 AM
Do you know the required dimensions - taper etc?
If so then can you find someone to turn you a pair?
Got to be easier to turn without the offset than with the offset.
From memory the MK supplied offset mushrooms for my Indy made me "adapt" a socket with an angle grinder to get it to fit and tighten the nut!
A non-offset mushroom would have been easier to use in this respect.
[Edited on 6/11/17 by nick205]
rj - 6/11/17 at 11:08 PM
I am sure I could make you some, I assume they will need a taper to suit Transit drag links ? My car has Cortina hubs but I do have a spare Sierra hub to make sure they will fit.
Daf - 7/11/17 at 06:43 AM
Sounds good, I'll put a drawing together in the next few days and take it from there
