Fitting helper springs
JekRankin - 23/7/20 at 12:18 PM
The front springs on my Fury are loose at full droop, so I've bought some helper springs and seats to sort it.
Slight issue though - the coil bound length of the helper spring is only 7.5mm. The helper spring seat has a lip of 6mm height, which means the seats will clash with the spring platforms on my Protech Shocks when the helper is coil bound. Faulkener suggest turning down the lip on their seats to resolve this.
I need a relatively quick fix, and don't have access to a lathe. I'm sure I've heard of people lock wiring the helpers to the main springs. Any quick fixes out there?
Jek
perksy - 23/7/20 at 07:33 PM
Any reason why you couldn't just fit the correct length springs?
JekRankin - 23/7/20 at 07:38 PM
That's what I thought originally, but changing spring length doesn't help unfortunately. The only quick fix would be to increase ride height.
Jek
Angel Acevedo - 5/8/20 at 01:13 PM
Could you not limit travel in Droop??
I think it has been done with straps (not elegant) or Mechanical stops.
HTH.
procomp - 5/8/20 at 01:55 PM
Hi common issue we have also.
do you want me to turn up a pair of protech collars to sort issue you can put them on top of your existing collars as ythey will be thin. ?
Cheers Matt
[Edited on 5/8/20 by procomp]
JekRankin - 7/8/20 at 11:00 AM
Thanks for the offer Matt....In the end I trimmed the lips on the existing collar and spacer down so they don't clash.
It took a while with a hacksaw and a file, but the helper springs are now fitted and doing their job as intended.
Jek
