Sorting the brakes after 9 years
roadrunner - 25/3/21 at 07:44 PM
Any advice on what to do with my brakes before I drive the car after 9 years in the garage.
It's my last job before I book it in for It's MOT.
Brad
ReMan - 25/3/21 at 10:58 PM
Move car to Un stick them, pump the pedal, drive slowly, check brakes
use them some more repeat?
roadrunner - 26/3/21 at 06:12 AM
Thanks.
I didn't know if it was worth buying new pads.
I have been pushing the car out of the garage so I know there not stuck.
Will just give it a fresh fluid change.
rusty nuts - 26/3/21 at 08:35 AM
Probably worth checking the calliper pistons move freely and the pads are not stuck in the callipers. Same for the rear brakes, check the brake linings aren’t separating from the steel part of the pads and shoes. also check the handbrake mechanism and cables are free
jacko - 26/3/21 at 05:48 PM
Hi Brad
Well done in getting the car ready for it’s mot I must say it’s about time only 9 yes 9 years bloody hell is it that long
Graham
roadrunner - 26/3/21 at 08:33 PM
I know Jacko.
When Al this hoo Haa is over I'll come take you for a spin. Remind you what you're missing.
