A few bits - Garage clearout
tims31 - 9/3/18 at 03:00 PM
Have a bit of a clear out in the garage so these bits are offered before they get thrown out if anyone wants them.
Pair of 5 3/4" headlamps with side light. E marked and H4 marked - Only fitted for a few months as now upgraded to LED lamps.
Come without the ring and backing housings but can be bought from SVC for £38. Have the extra bright halogen bulbs fitted too. One of the side light rubbers has a slight tear in it but holds the bulb fine.
£30
Sierra steering wheel - Does not have the slipper ring as I still have that fitted to my hub. The centre cap has one of the plastic tabs broken off but I made a metal clip to hold it in and passed IVA with it just fine, can't be seen once fitted in the wheel.
£10 - SOLD
Sierra 1.8 Sapphire master cylinder and reservoir with level warning cap.
£10
various lengths of 32mm silicone hose £10 the lot
450mm -
370mm -
2x150mm
2x60mm - SOLD
Not sure if this is of use to anyone - Sierra 1.8 CVH distributer cap and rotor arm.
All items are plus postage
[Edited on 10/3/18 by tims31]
[Edited on 11/3/18 by tims31]
starterman - 9/3/18 at 09:25 PM
Can I have the steering wheel please. PM me some details and I'll sort some shillings out if that's ok.
Mike
tims31 - 9/3/18 at 11:39 PM
U2u sent
Just need to weigh it for postage.
wowblaauw - 10/3/18 at 08:03 AM
Hi, I’ll take the hoses, please pm me the details. Thanks, Craig
simon h - 10/3/18 at 12:06 PM
If you can do £30 posted for the headlamps I'll have them.
Cheers Simon
tims31 - 11/3/18 at 06:29 PM
Cheers Simon
Yep okay, U2u sent
tims31 - 14/3/18 at 11:35 AM
headlamps, Steering Wheel and hoses all sold
Anyone interested in the master cylinder or dizzy?
JonBowden - 16/3/18 at 01:15 PM
I might be interested in the master cyl.
Do you know what bore it is?
tims31 - 16/3/18 at 02:08 PM
Hi Jon,
Having had a look and researched the numbers I think it is 22.22mm. Was fitted to a Ford Sierra Sapphire 1990 1.8CVH
HTH
