wanted Twin SU carb connecting rod linkage for chokes
bill132hotrod - 20/7/19 at 05:51 PM
Hi guys
This is a long shot I know.
But does anyone out there have a old set of twin SU carbs 1.1/2"
(I am looking for the choke connecting rod linkage that joins the (2) chokes together)
Any one ????????????
Thanks in advance
rusty nuts - 20/7/19 at 06:26 PM
Might be able to get one from an MG specialist? Nice to see your still about Bill, do you still have the Luego?
Mike Wood - 20/7/19 at 07:22 PM
Try Andy Jennings MG Spares for secondhand bits: https://www.mg-cars.org.uk/andyjennings/
Or Mechspec for secondhand MGB bits: http://www.mechspec.co.uk
If not MGB Hive: https://mgbhive.co.uk/product-category/mgb/
Or Rimmer Bros: https://rimmerbros.com/Item--i-GRID019709 (also will have SU stuff for Triumph etc)
I should have asked what engine are these carbs on? As there are twin 11/2 inch SUs on many Triumph, MG, Austin etc vehicles
Burlen Fuel systems supplies many SU parts: http://sucarb.co.uk/linkage-parts.html
Mike
[Edited on 20/7/19 by Mike Wood]
cliftyhanger - 20/7/19 at 07:53 PM
The bar itself is just 5/16" (8mm will work but needs fettling at the ends)
But if you need the clamps it could mean a specialist. Burlen being the people to speak to.
r1_pete - 20/7/19 at 07:55 PM
Burlen will have all you heed
http://sucarb.co.uk/linkage-parts/hs-linkage-kits.html
bill132hotrod - 20/7/19 at 08:14 PM
Cheers Guys
Ordered from Burlens
Hi Rusty
Yes I still have the Luego but not used it much over the last couple of years,
Bill
