Looking to do an engine swap in the near future. Let me know if you have any Rx8/AJ30 project parts. thanks!
I've got all sorts of spairs, but mostly the wrong ones! Where do you live?
I'm in the midlands - Near Nottingham. What about you?
I'm in Brighton, so not quite down the road. What sort of components are you looking for? I have an inlet manifold for the 2.5L Ford engine,
like the ST200 version but with smaller ports, and other similar bits.
Things like the adapter plate etc I only bought one of and I'm using so not much extra really.
What are you putting it in?
I'm very much at the early stage and investigating options like what ECU to use, 5 v6 6 speed rx8 box, reducing the height (with the st220
inlet).
It will be going in this;
