Megasquirt wideband
Myke 2463 - 19/7/09 at 10:03 PM
Whats the best / cheapest wideband sensor to use in a zetec when logging and can it be left in place when completed.
Cheers Mike.
mark chandler - 19/7/09 at 10:21 PM
Hmm I have a self built JAW, cheap but support is pretty rubbish and took a few goes to make a success of it, if I knew what I know now I would get an LC1
Once on the car you can leave in place, or remove its up to you although I am not sure why you would remove it.
omega0684 - 19/7/09 at 11:28 PM
lc-1 is worth the investment
major - 20/7/09 at 04:58 AM
I would say Tech-Edge.
marcel.
Benzine - 20/7/09 at 07:56 AM
Techedge vs LC-1
matt_gsxr - 20/7/09 at 08:51 AM
I got an LC-1 shipped from the US.
It is great. You can leave it in permanently.
Matt
major - 20/7/09 at 03:41 PM
Originally posted by Benzine
Techedge vs LC-1
Mixed comments about the LC-1, never heard a negative comment on the Techedge.
Marcel
matnrach - 20/7/09 at 06:51 PM
I have an LC-1 which is permanently connected to my MS for closed loop on output 1 and a DB gauge on the second output.
It works fine.
No problems at all.
flak monkey - 20/7/09 at 06:52 PM
It works fine.
No problems at all.
What he says. Its spot on
fatbaldbloke - 20/7/09 at 09:27 PM
I have an LC1, never had a problem. However I run in open loop and only connect it for datalogging as I think it looks naff sticking out the top of the external exhaust.
Jenko - 11/8/09 at 12:55 PM
Techedge has worked fine for me.....
Only gripe...I bought the digital display which has broken after getting a little wet....
Paul.
MikeRJ - 11/8/09 at 01:03 PM
Tech Edge would be my first choice, quality of design and support is first rate.
The Innovate products are pretty good too, but there have been quite a few failures of the heating circuit in the LC1.
My JAW sits in a box of other bits of electronic junk, exactly where it belongs.
[Edited on 11/8/09 by MikeRJ]
