Throttle Position Sensors
perksy - 3/7/11 at 09:02 AM
Looking for a 3 wire 'D' Type Drive Throttle Position Sensor
Have Had issues with the COLVERN ones in the past not lasting and causing fuelling issues etc
Has anybody found a Good solid reliable one and if you have where from ?
Wondered if anybody had found one off a normal production car that could be used ?
Looked at the 'Contactless' ones and although i beleive they're very good, there also around £100 a go
big_wasa - 3/7/11 at 09:29 AM
I would be having a look at the rover K series tps. Depends on the scrapie but I recon I would get a handfull for a fiver at my local.
[Edited on 3/7/11 by big_wasa]
ashg - 3/7/11 at 03:06 PM
i have got one of those if you want it.
clairetoo - 3/7/11 at 04:42 PM
/ that looks a lot like the one on my Triumph throttle bodies - I've got a few of those spare since I use two sets for a V6 , and remove one to fit the linkage - I could bung one in the post ?
RazMan - 3/7/11 at 05:18 PM
The Ford ones are pretty good - Duratec ones can be clockwise or anti clockwise depending on models.
atspeed racing - 5/7/11 at 11:40 AM
colvern ones can cause problems over time.
want reliability and accuracy? try a penny and giles sensor. (around £90)
- colin
