where to buy a kit car loom?
daniel mason - 28/3/11 at 08:17 PM
is there anywhere i can get a loom for my mnr? just to control lighting,fan,horn,handbrake and brake pressure etc. engine loom is in and seperate to car loom.
wylliezx9r - 28/3/11 at 08:26 PM
I got mine from premier looms, he will make it to your spec, I havnt fitted it yet but it looks top quality and came with full instructions, it even came with its own crimpers.
T66 - 28/3/11 at 08:28 PM
While I havent yet bought from premier looms, I rang them recently and found them to be very helpful.
Can make anything to your spec
big-vee-twin - 28/3/11 at 08:28 PM
Just finished installing my Premier loom, no problems high quality
I think SVC make a basic loom too called uni loom
adrianreeve - 28/3/11 at 08:37 PM
Another vote for the premier loom!
fluidslvr - 28/3/11 at 08:52 PM
give eddie99 a shout on here..
quality loom with instructions..recommended
embraboy - 28/3/11 at 09:00 PM
Another vote for Premier Wiring. Alan is really helpful. Loom can be customised to what you need and comes with clear instructions.
http://www.premierwiring.co.uk/
simonwinn - 28/3/11 at 09:01 PM
Another one for premier, Alan is very helpful.
AndyW - 28/3/11 at 09:10 PM
Another for premier, Alan is a good bloke, really helpful and will built it to do as little or as much as you want.
GeorgeM - 28/3/11 at 09:15 PM
why not get the proper one from MNR ?
it will fit properly then.
daniel mason - 28/3/11 at 09:33 PM
didnt even know mnr did them?
snowy2 - 1/4/11 at 07:37 AM
wiring does not require the sacrifice of any chickens or anything, it is very easy to wire up a kit car, Here is a link to an article i wrote some years ago and is posted somewhere on a locost forum,
http://www.andersensmith.freeserve.co.uk/wiringloom6.pdf
it does cover the subject your asking about. and here is a link to something about using relays (for fitting cooling fans)
http://www.godspeed.me/forums/viewtopic.php?f=14&t=1289
ceebmoj - 15/11/11 at 10:57 AM
Does any one have pictures of a loom from
MikeFellows - 15/11/11 at 12:12 PM
i tried contacting premier for over a month, no reply to emails and one mobile dead, one to voicemail.
i gave up 2 weeks ago and someone linked me to eddie99 on here, its due in the post today or tomorrow
edit to add that they have updated their site in the last 2 weeks now so who knows
[Edited on 15/11/11 by MikeFellows]
snowy2 - 16/11/11 at 05:49 PM
I have posted various links to full instructions on wiring cars. if you were able to build your car why wimp out on the electics? wiring a kit car is a doddle, give it a go you'll surprise your self.
RK - 17/11/11 at 01:25 AM
Snowy2 has provided EXCELLENT advice in his articles. I have done my car 4 times now (and my car has not yet been on the road), and had I seen his information, I would only have had to do it once. I have made a bodge of it every time, but at the moment, it works. Next year, I'll take it apart and do it properly. I had trouble figuring out where to put the fuses, junction boxes (of which I have many) and relays. I just couldn't visualise things.
It is not easy, however, and is very very hard on your back. Also, my crimping is terrible, much worse than my soldering. Many earths have come loose, which has been very frustrating. I wish I had someone to do it all for me, but I don't so I have to just carry on as usual. I do feel it is misleading to tell people that it is a doddle, when it clearly is not; last go took me 6 months of solid, continuous work. It can be a rat's nest of wire under your dash if you "just do one wire at a time". No, you need to know what you are doing, or risk blowing a lot of fuses or worse, cause a fire.
