Tiger loom and ecu power.
furryeggs - 24/5/16 at 07:06 PM
I have the standard 6 fuse tiger loom that i have labelled up and identified 95% of the wirining. Theres a couple of unidentifiable wires that I'm stiil attempting to match to the 10 completely different diagrams that are floating around the www (still struggling with ignition wiring)
I have got the wires identified and labelled that are used for distributer and coil (white/black and white) can i use these to supply my ecu, or is it best to run new wires.
neilp1 - 25/5/16 at 05:05 AM
I ran in new wires and discarded theses.
This was my least favourite part of the build!!
Schrodinger - 25/5/16 at 07:47 AM
I used the ignition wiring on my cat.
If you are having trouble identifying the wires try asking on http://www.tigerownersclub.co.uk/forum.html there are people from Tiger on there who should be able to help.
wombat - 25/5/16 at 10:30 AM
Hi,
Like Neil this is not my favourite part either, really worried im going to fry one of the expensive components !
I have identified all my wires and connected them via blocks ready for connecting the battery as soon as my water temp sensors are fitted any day now GULP..........
Wombat
furryeggs - 25/5/16 at 11:08 AM
wombat... What wires have you taken to your ignition?
