Help. Trying to find UK source of 16 way connector.
TimC - 3/12/16 at 10:09 PM
I need the LBs knowledge bank: I need a 16way plug-in wire connector so that I can remove my switch panel if needed.
Ideally something like:
But splashproof not totally necessary.
I can't afford to wait until January for the part to arrive from China.
Any ideas?
Ta.
gremlin1234 - 3/12/16 at 10:23 PM
if I needed it absolutely immediately I might re-purpose an old TV scart connection
but there are many better
https://en.wikipedia.org/wiki/SCART
look to farnell or rs components (or even maplin)
Madinventions - 3/12/16 at 11:32 PM
Brand Hatch Performance on eBay sell pre-packed Mate-N-Lok and Econoseal connectors which may suit your needs. Not necessarily the 100% cheapest way to buy these connectors, but very convenient and plenty of options. Used plenty of them on my dash in my Mojo and no problems so far 7 years later.
Here's a 15-way version: http://r.ebay.com/MI2pto
eBay Item
Ed.
Andy S - 4/12/16 at 04:16 PM
Simtec have a few solutions
Tazzzzman1 - 4/12/16 at 07:15 PM
http://cpc.farnell.com/te-connectivity-amp/182642-1/cable-socket-plug-16-way/dp/CN01872
or
http://uk.rs-online.com/web/p/automotive-connectors/7561101/
or
http://uk.rs-online.com/web/p/automotive-connectors/8010991/
Might be of some use
SteveWallace - 5/12/16 at 09:42 AM
Does it have to be a single connector? Vehicle Wiring Products (based in Ilkeston, Derbyshire, but they do mail order) do a range of connectors, but the biggest is only 15-way. Could you use two 8-way?
VWP
britishtrident - 5/12/16 at 09:58 AM
Even if you can get a 16 way splitting it into two or even three is sensible.
loggyboy - 5/12/16 at 10:06 AM
Out of stock but these (generally listed as military connectors) come in that many 'ways'.
http://uk.rs-online.com/web/p/mil-spec-circular-connectors/8721575/
[Edited on 5-12-16 by loggyboy]
lsdweb - 5/12/16 at 11:24 AM
Mate N Lock - only 15 way Tim, but as said above use a 9 and a 6 (try to avoid using two 8s as there's a chance of connecting them up wrong!)
http://www.polevolt.co.uk/acatalog/Mate-N-Lock_Connectors.html
[Edited on 5/12/16 by lsdweb]
TimC - 5/12/16 at 01:10 PM
Thanks all for the suggestions; I've bought Male and Female OBDII sockets to have a look at - failing that I will split the requirement in two.
Oh, and Wyn - what's 9 + 6 = ?
lsdweb - 5/12/16 at 01:29 PM
I could have probably been a bit more accurate Tim but you know what I meant!
