Voltage stabiliser
PAULD - 24/4/20 at 12:57 PM
My car has the complete instrument panel from a mk4 cortina. Does anyone know if it is possible to access the voltage stabiliser and if so what voltage should it be giving.
theconrodkid - 24/4/20 at 01:51 PM
stab should be on the back of the speedo / gauges, should be around the 9 volt mark
ken555 - 24/4/20 at 01:52 PM
I would guess 10 Volts as most of the smiths range run on that.
I replace them with a 7810 chip.
[Edited on 24-4-20 by ken555]
Mike Wood - 25/4/20 at 08:22 AM
I wonder whether wiring in a replacement external voltage stabiliser would be an option, e.g. Lucas one for Smiths gauges:
https://www.merlinmotorsport.co.uk/p/smiths-voltage-stabiliser-cb-vstab
https://www.holden.co.uk/p/voltage_stabiliser_negative_earth
https://www.autoelectricsupplies.co.uk/product/1062/category/195
Best wishes
Mike
[Edited on 25/4/20 by Mike Wood]
PAULD - 25/4/20 at 12:08 PM
Thanks for the suggestions, I'll look into them.
