VAGCOM VCDS info
bi22le - 1/8/15 at 02:29 PM
Hi.
I have a B8 Audi A4. The brakes need doing and although I may not need VCDS to turn off the warning light I know it will come in use. For example, i want to unlock the secret green screen to access some freebie upgrades.
The crazy price differences on ebay frightens me, I can get it from £5-300.
I have no doubt the cheaper end is just Chinese leads a ripped off copy software but does it work?
At what price does the gear start becoming legitimate and worth the money?
Any advice or experience?
Slimy38 - 1/8/15 at 04:10 PM
Basically the older version of the software was really insecure and is everywhere for pennies, whereas the updated version is a lot harder to get a copy of. And the older software only works with older cars, up to about 2004 depending on what VAG car.
I'm afraid for a B8 it won't work. You might just about be able to get the fault codes, but forget the freebies. Which is a shame, because my 2001 got a whole load of stuff added when I got mine, and it cost me about £15!
Have a look at the official page;
http://store.ross-tech.com/shop/cat/VCDS.html
To understand the various packages and their related official versions.
CosKev3 - 1/8/15 at 04:27 PM
Find someone locally off a vag forum that's got the full version and bung them some £££ to do it
v8james - 1/8/15 at 04:41 PM
I bought a cheap one from ebay for my sons 2004 golf, it also works on my 2012 Passat.
Dokez - 1/8/15 at 04:46 PM
I have genuine vag com and im in Dartford if this helps you. If you have a how to guide should be fairly easy!
Pm me
bi22le - 1/8/15 at 05:54 PM
Thanks for the offer Dokez.
Im hosting a BBQ at the mo so will U2U you later.
Dusty - 1/8/15 at 10:16 PM
I have two polos, ex wife has a golf and two of the kids have fabias. I bought a genuine VCDS for about £280 three years ago from Ilexa, the UK agent. It has saved me hundreds of quid. I don't know how anyone works on a VAG group car made in the last 15 years without one. (I did try a cheapo VagCom copy which was a waste of time)
p.s. don't buy a pre 04 fabia if you value your sanity.
mistergrumpy - 2/8/15 at 09:38 AM
I have VCDS for my T4. Just downloaded the free demo from Rosstech site, bought an Ebay lead and then registered the demo with Rosstech for $99 and this this gives you what you need. Albeit, I don't think my copy will will across the range, just for a limited number of engines but it does me fine.
