Right chaps / chapesses.
Read slowly, the following is the work of a confused mind.
The new tin top of Zil is one of
these
It has a basic sort of single CD radio just now, but you can get an OEM looky likey SAT NAV setup for it which runs on Windows CE, much like this
one.
Base on this being windows CE and having bluetooth, I'm thinkinng it might be possible to run one of the OBD readers on it along with an ELM327
based OBDII bluetooth deviced plugges into the diagnostics port.
There is software available which gives you access to the OS to run such software.
Thought anyone ?
[Edited on 28/8/11 by zilspeed]
You have too much time on your hands.........................................
