DIY roof at home
l0rd - 7/7/12 at 07:13 AM
I need to replace the roof at the building i live in.
There is a program called woodexpress that would help me out a lot but at 700+ euros just for one design isn't worth it.
I have called a couple of pros to do it but no one came back with a quote.
I believe it is down to me to DIY
The roof has an angle of 4 degrees so it is nearly flat.
Can anyone help me out?
rusty nuts - 7/7/12 at 08:09 AM
I did the flat roof of the garage I built 35years ago , used plywood sheets over the joists followed by 3 layers of felt IIRC the first was nailed down using felt nails , the second used hot pitch and the third was top layer felt (mineral?)again with hot pitch . The roof was still water tight 15 years later when I moved outand AFAIK is still on. It helped that I was able to borrow the gear to heat the pitch but I think its possible to do it using a propane torch? Total area was 400 sq ft , did it all in one day. PS used a triangular edging on the sides and rear edges which was felted over to stop water running off
zilspeed - 7/7/12 at 08:37 AM
If you can wait to monday, I can show you some drawings for one I did about a year ago.
As a starting off point though, some things to consider.
1) Do you want a level ceiling inside or can you make do with the ceiling following the pitch of the roof.
2) Will the roof drain at the perimeter or somewhere in the centre.
3) Do you have a suitable wall head arrangement to use a simply supported joist ?
4) Do you need to insulate in any way ? (I see you're in Greece.)
It may also be helpful for you to consult Trada (or similar) span tables.
This can help specify suitable timber sections along with timber grade and joist spacing.
Here's an example.
http://www.bsw.co.uk/uploads/files/bsw_timber_c16_span_leaflet_a4 _4pp240810.pdf
I used C24 grade for my project, the table above is for C16 grade timber.
Just some preliminary thoughts.
It would be helpful if you could provide some images or a link to some images.
Use Bing Maps, you may get a birds eye view from there. This can be really handy.
The building (hopefully) right in the middle of this image is the one I did last year.
I used a combination of ideas to make this one work including level joists and firring pieces along with an area with an angled ceiling. This one drains in the centre. I also changed the design to make it more inherently vandal resistant.
Here's the link to the birds eyed view before our new roof.
http://binged.it/Mabzvr
As I say above, I have loads of cad drawings of this one in the office, but it would be monday before I could access it again.
Zil
l0rd - 7/7/12 at 08:50 AM
difficult to see a pic of it on bing
I will provide a drawing latter.
JacksAvon - 7/7/12 at 01:58 PM
http://www.rubba-seal.co.uk/
have a look at this option
l0rd - 7/7/12 at 03:03 PM
this is the one in question
the brown line is supposed to be a column
[Edited on 7/7/12 by l0rd]
l0rd - 7/7/12 at 03:10 PM
Zilspeed
The roof as you can see in the image is nearly flat.
the ceeling will follow the pitch of the roof
the roof will drain on the front and back.
The utility room in question have 20cm level thick walls arround. The dimensions of the room are
6m wide by 3.4m long
Between beams, i will use plasterboard and insulation? Not 100% sure where insulation will go but there will be insulation.
