building/land surveyor wanted
matt.c - 30/7/12 at 08:17 PM
Can any any building/land surveyors help me with this problem?
HELP
Im getting desperate now.
designer - 30/7/12 at 09:57 PM
What about the survey you will be getting done?
matt.c - 30/7/12 at 09:59 PM
Yes. Just need advise on what will be in the survey and if its going to point out whats wrong and how to fix it.
zilspeed - 30/7/12 at 10:05 PM
Unless you specifically ask for an actual survey, you may actually be getting no more than a valuation.
You need to be very specific about this.
The clue is in the fee being charged.
matt.c - 30/7/12 at 10:09 PM
Ok im an idiot. What does this mean.
tegwin - 30/7/12 at 10:13 PM
A valuation type survey will be cheap (ish)..... A full land/geological/topo survey looking for underground streams/drainage etc will cost a LOT
[Edited on 30/7/12 by tegwin]
matt.c - 30/7/12 at 10:16 PM
As the place is under 10 years old we went for the basic report (not the home buyers report).
I think the major report was over £1000
tegwin - 30/7/12 at 10:19 PM
That does not suprise me... and I suspect it would still not cover enough to help you with your squidgy lawn...
matt.c - 30/7/12 at 10:22 PM
Found this: look
Still even on the major inspection it doesn't seem to cover much on the outside of the house.
theconrodkid - 31/7/12 at 06:24 AM
i used to work for a co that did this sort of stuff.
water can be a killer on houses,you need to find the geoligy of the area and where the water mains run.
you could try water devining,it does work,that would give you a clue as to an underground stream.
personally,i would walk away
