Polish scratches from Styrene window
number-1 - 5/7/23 at 05:46 PM
Can anyone suggest a way to remove scratches from a summerhouse window?Its a Styrene window and was left for 3 years with the green film on both sides, which in the sun over 3 years went brittle and wouldn't peel off in 1 piece.
I took a blade to it but as the Styrene flexes its left scratches at each end of the blade on several places
Does anyone know if there's a way to polish them out?
N1
indykid - 5/7/23 at 10:07 PM
I'd replace the sheet. How big is it?
You might get away with brasso, it was what we used in school for acrylic projects, but it's always going to look a bit secondhand unless you can bring the surface around the scratch down to the same level as the root of the scratch.
number-1 - 6/7/23 at 02:43 PM
Hi mate
Its around 1550mm x 620mm at a guess.
