ariston machine fuse went in plug now replaced the door wont open, i've run the machine through its cycle again but the door light still wont go
out, any help from you good lot on here before i call in a washing machine man in.
[Edited on 17/5/06 by graememk]
Buy a new one and use the old drum for an exhaust heat shield????????
dont want to buy a new one as it eats into my car budget.....
Just had a similar problem with a Hotpoint w/m. It turned out to be the door switch / solenoid.
yep door switch solenoid would be favourite.
Ray
Will it open with the power switched off ? The solenoid on ours is on a timer but when the power is off it will open so it could be the delay
timer.
[Edited on 17/5/06 by Peteff]
many times the washing circuity
need that the basin is empty of water.
When the process is interupted, the only way to make sure the basi is empty is to do a centrifugal round.
its what i did when i had some similiar problem.
The pump will pump the water out and then the centrifugal process will start.
at the end you should be able to open up the door.
you risk that opening it forced(fooling circuitery etc.) that the basin is full of water.
Tks
There is a drain function on most Aristons. Turn the dial to the little symbol with the bowl and arrow and turn it back on. You should hear it pump out, I did this last week when the missus decided her mobile needed a daz doorstep challenge.
looks like it might be the door solenoid, hence why the fuse blew when she turned it on, i found a local guy that does call out for £20, can not waste
garge time fixing washing machines can i he he he
Ezee Fix
Try this forum. Its very good. You can also order parts at a great price. I can recommend this site highly.
could just be the door stuck shut and because its stuck not registering as shut if that makes sense ...
take the top off reach down inside it and release the door catch open it and shut it again see if it works as a possible easy fix (happened to my
aunties) but make sure you switch it off and not switch off the fridge instead otherwise you are likely to get a really bad electric shock going up
your arm and then jumping out of it wherever it is in contace with the washingmachine casing leaving you with a couple of entry nd exit wounds
surrounded by tasty burns
interesting side note ... why are burn dressings flammable
