Did you have any problems with ground clearance with your Alfa V6 engine? Did you fit a shorter sump?
Your engine seems to fit OK without having to modify the bonnet, but the problem I'm having is height issues.
Even with a shortened sump it will be a good bit taller than a standard height Ford Zetec
Any information would be very useful
Thank You
Hi
Sorry for the late reply
I used the sump from an Alfa 75 V6 also the Oil pump, this reduces the overall height by around 50mm and allows clearance under the bonnet.
My cai a Viento, this has additional room under the bonnet any way but i think the finished height top to bottom was around 620mm
Hope this helps
john
my solution
owelly solution
Thanks, that gives me something to go on.
Just to agree with Johnmor's measurement - I measured my v6 as 680mm top to bottom.
