turbo or supercharger for 1.6 zetec se
pocket rocket - 3/10/09 at 02:08 PM
i am thinking about a turbo or a supercharger for my 1.6 zetec se engine to increase its modest 100bhp.
rotrex do a supercharge kit but its alot of cash
any idea what the cost might be to fit one or the other???
if anyone has pic's of one fitted or a list of the parts needed to do the job that would be ace.
it only has to be a small turbo or SC as im sticking with the standard internals
many thanks
Madinventions - 3/10/09 at 02:12 PM
Have you seen Paul Collingwoods 1.6 mods? 194bhp without turbo or SC... Probably just as expensive though!
The mods to my 1.6zetec are
ported cylinder head
high lift cams
pocketed pistons
steel rods
active technology throttle bodies
larger injectors
and mapping at emerald rolling road
I built the engine my self so yes I am pleased with 194 bhp
thinking of fitting forged piston , bigger valves and new exhaust when I have the spare cash
Linky
Ed.
thunderace - 3/10/09 at 02:13 PM
i will be intrested in this also,always wanted to supercharge a car.
pocket rocket - 3/10/09 at 02:22 PM
194bhp with no turbo or sc is very good work, but like you said very costly
my budget is low for this so it does need to be a locost special
the plan is to make the exhaust system and any mounts needed my self to save £££ and spend it on the ecu which i think is going to be the most expensive part.
Madinventions - 3/10/09 at 02:27 PM
I've got the teeny 1.25 Zetec in my Mojo (75BHP) and I think I'll upgrade to the 1.6 at some point soon. You can always do with a bit more power!
I agree that Pauls mods are probably expensive, and I'd love to see what Turbo/SC mods this thread shows up.
Madinventions - 3/10/09 at 02:55 PM
Here's a supercharged 1600 Zetec-S project... Uses an Eaton M45.
Linky
1600cc all alloy 16v Zetec SE
Eaton M45 Supercharger
Behr Chargecooler (Watercooled inlet charge)
DTA S60 pro ECU
Probably expensive too! <sigh>
And here's a fairly good article regariding the Zetec-S/SE tuning:
Linky
pocket rocket - 3/10/09 at 03:42 PM
there is some great pic's of the engine with the supercharger and charge cooler fitted
interesting how the article on zetec se tuning says not to go down the forced induction route and to just go N/A when people seem to be having sucsess with supercharging.
rossymond - 3/10/09 at 04:15 PM
It might be worth looking at using something like the carger from a mini cooper s? or from a golf g60? would be much cheaper to buy than a new one i would have thought, management wise look at something like a greddy emanage, then look at someone like Ryan G from 2bar tuning to fit and map it, he's a mate of mine so ask if you need some details.
small intercooler, bigger injectors and a decent walbro fuel pump and your away.
the only hard bit would be mounting the s/c and fitting the belt/pulley system.
goodall - 3/10/09 at 05:34 PM
why not just fit a 2l zetec gota be cheaper and easier with after market ecu and the trimmings would work out better that a forced 1.6?
however, if still think supercharger is the way, for there are some nice aspects to doing it i got to admit. how about a used super charger of a new mini cooper, i think there had cheap on ebay coupled to a cheap charge cooler and adequate ecu would be fairly straight forward
RickRick - 3/10/09 at 07:14 PM
my Zetec S fiesta with 1.6 engine was turbo'd by van aaken developments however there not trading anymore, my car was used for the development, resulting in a blown turbo after 3 weeks, but once repaired, my 103 hp went up to 155 and loads more torque was brilliant on the motorway in 5th would have been ace if i'd removed the power limiter from 1st gear
pocket rocket - 3/10/09 at 08:58 PM
what was the cost of the turbo kit rick? im temped by a turbo as you can pick up small turbos like a ct26 very cheap and won't have the fuss of mounting it straight for a belt like a SC, i looked at the eaton 45's like the cooper s one, they are fairly cheap but much more than a cheap turbo!
can you remember what boost the turbo was putting out? im sure i remember 0.3bar from somewhere
my biggest worry is the ecu and the cost, i don't understand ecu's
pocket rocket - 4/10/09 at 07:48 PM
there are a few 2.5lt turbo st engine + gearbox's on ebay, start at £750... now thats very tempting
Steve PH - 4/10/09 at 10:57 PM
I supercharged my 106 GTi trackday car. The results were pretty good, it went from 125 to 199 bhp atw but I wouldn't call it a cheap conversion, it needed forged pistons to work properly, intercooler, management etc.
Proper little toy on track but doesn't get used so much now I've got my Westfield
FlansS14 - 29/12/09 at 08:12 PM
my mate had a conv from them.... What a bodge! No wonder they went out of buisness....
I know this is an old thread but you do realise the 1.6 se engine is 11.5:1 CR.... Not ideal to turbo. However it is a fantastic engine and soooo light. We had a STD one on emerald and it sounded so Nice at 8200 rpm.
beaver34 - 29/12/09 at 08:36 PM
i run a se engine, in N/A form, stock bottom end, bodies cams headwork 175bhp, revs to 8k
boggle - 29/12/09 at 09:51 PM
t2.5 and a decompression plate with a 5th injector...tis as simple as that...
beaver34 - 29/12/09 at 09:53 PM
not really that simple is it,
boggle - 29/12/09 at 09:56 PM
it is...i have done it....
beaver34 - 29/12/09 at 10:05 PM
no messing with exhaust to fit a turbo?, no sorting the fuelling out? the pipework for the setup?
boggle - 29/12/09 at 10:14 PM
this was my first attempt in 2001...
it was on an escort cabriolet 1800si
it had a t3 turbo, 2mm decompresion plate and a 5th injector...
done on a budget of £500....and i was only 21 at the time....was my first big project...
i made the manifold adaptor and just reused bits from an rs turbo.....5th injector is from a cosworth and is plummed in from the end of the fuel rail where you test the fuel preasure...it is controlled by a preasure switch.....
when im bored with the pinto i will do a 2.0l one.....have learnt a lot since then so will make it better...
beaver34 - 29/12/09 at 10:20 PM
fair enough on that engine as the parts are there and fit and alot of people do zetec turbo's, there are very little turboed zetec se engines or parts for that matter, ford are releasing a turbo version of it soon though so that should change things for the better
boggle - 29/12/09 at 10:32 PM
i must appologise, i didnt read the se bit....doh!!!......im sure MAD devolpments did a conversion for the se...i know they used to do a conversion for the 1.7 puma and the ford ka....im sure it would not be too difficult to do....
boggle - 29/12/09 at 10:41 PM
if anyone is thinking of turbo charging one and wants some help i would be interested in lending a hand....
NS Dev - 30/12/09 at 09:48 AM
I'd go with the supercharger myself.
Yep its all do-able on the cheap but prob won't be very effective.
Obviously the pic above is zetec not zetec SE, different kettles of fish entirely!
Also very different job fitting it in a locost!
If money were less of an issue then either fit a duratec, or if you want to stick with the SE (and they are light and nice engines) then a small rotrex blower would be perfect, just not cheap!
terryroberts - 31/12/09 at 11:05 PM
hi guys if you can hang on till mid 2010 then fords will be putting out a 1.6 turbo sigma motor will 185bhp as std. so to be followed with a 230bhp one..
cheers terry
beaver34 - 1/1/10 at 12:14 AM
cheers terry
thats what im waiting for, so i can buy off the shelf stuff if it will fit, working for ford also helps
joe90 - 28/2/10 at 01:18 PM
Hi - I'm new to this forum - planning to build a Sylva J15 - interested in tuning a zetec SE - would like to get hold of Paul Collingwoods' spec for the parts he used.
Any help much appreciated - Cheers
beaver34 - 28/2/10 at 07:16 PM
have a look at the shawspeed website, i will have a 200bhp se in around 2 weeks built with jons parts
ncoll - 28/2/10 at 08:04 PM
I am sure Paul wouldn't mind me telling you the spec of his engine, the cylinder head is one of my flow benched developed standard valve size fast road heads. The cams a rally spec, standard pistons but with pockets in, steel rods. It has 38 mil throttle bodies, exhaust manifold is standard road car riot. The car develops 192 bhp at 7900rpm. I am at present developing a big valve head for this years engine. I will put a graph on of the big valve flow and percentage increases later. The reason it is a fast road head is that this was all it was going to be used for in the beginning. Then it became a trackday car, then a race car, but still with the drivability of a road car.
neil collingwood
ncoll - 28/2/10 at 08:37 PM
This is a graph of the big valve inlet port flow of the SE development head, below it to the right is the percentages increase in flow, i have now got to start on the exhaust.
neil
[Edited on 28/2/10 by ncoll]
pocket rocket - 24/3/10 at 06:48 PM
wow thats impressive!
just going back to the emerald ecu, is it a plug and play job?...
Can i just ditch my ecu, plug in the emerald with standard injectors, inlet manifold etc and have myself 8k RPM and a few extra horses... and then rolling road it when i add new cams, inlet etc or is it not as simple as that?
i might be able to live without a turbo if i can have an 8k rpm engine
beaver34 - 24/3/10 at 10:26 PM
to rev to 8k your going to need to do the valve spring on the head to stop valve bounce, also rod bolts, only shawspeed make them for the se engine as far as im aware, no point revving it that hard unless the cams are desinged to give power that high, it will need to be mapped before, if you were running omex on at shawspeed has base maps for differnt setups you can use,
cr500dom - 2/5/12 at 03:24 PM
Linky
DTA S60 pro ECU
Thats My Kadett project
Thanks for the kind words.
Its not as simple as "Bolt on a mini charger" though, the case needs modifying, mounts need making, the manifold is a custom one off with the chargecooler etc etc.
You also need a new water outlet / thermostat housing to suit.
I have just got hold of a Lysholm Supercharger for Phase 2 engine build so the original set up will be for sale complete once I know the new charger will fit
Dom
Norfolkluegojnr - 2/5/12 at 03:34 PM
HOLY THREAD RESURRECTION BATMAN!
2yrs 2 months. gotta be a record......
cr500dom - 2/5/12 at 03:55 PM
The power of google you see
beaver34 - 2/5/12 at 04:53 PM
allways looked at your thread wandering how it turned out!
cr500dom - 2/5/12 at 05:00 PM
Its still ongoing, back on it again after an enforced layoff due to life and logistics getting in the way !!
latest development is getting it up and running on AT-Power throttle bodies initially, then add the new lysholm supercharger to ITB Set up as well
More up to date thread is here: http://retrorides.proboards.com/index.cgi?action=display&board=readersrides&thread=36727&page=25#1571059
Dom
Steve PH - 2/5/12 at 06:45 PM
Since I last replied (two years ago!) I've supercharged my Westfield, these are the before and after dyno results -
beaver34 - 2/5/12 at 09:16 PM
Cool,
I'll check the thread out
This is mine itbs and turbo zetec se, on engine dyno next week
cr500dom - 3/5/12 at 02:53 PM
Nice !!
Have you got any more pics of the Jenvey Plenum ?
beaver34 - 3/5/12 at 04:21 PM
Nice !!
Yeah loads, any spesific bits of it?
cr500dom - 18/5/12 at 07:12 AM
Nice !!
Just some general views of it, internals and outside, there is not a lot of info on their site about it ?
I will need to do something similar when I fit the lysholm and I`m currently looking at making a carbon airbox "BAck plate" that can work for N/A initially and then take a balanced pressure twin plenum for when I pressure charge it.
many thanks
Dom
[Edited on 18/5/12 by cr500dom]
dexion7 - 8/7/12 at 09:22 PM
neil collingwood
off topic slightly but I bought Paul's Riot (less engine) and its getting a busa turbo in it!
BaileyPerformance - 9/7/12 at 12:44 PM
No need to decompress a turbo zetec if you go for engine management such as megasquirt.
We have run 20PSI of boost on a stock 2.0L (9.5/CR) using 98RON with no sign of detonation.
Most of the big tuners are raising compression on there turbo conversions not lowering it, this has been the trend for afew years - i beleave Mountune started this trend with there Cosworth YB turbo rally engines (10/1CR 1bar boost 300BHP)
Lower compression is only a must when you are running very high boost levels or poor fuel or poor engine management.
De-compressing a motor makes throttle response worse and lowers MPG during normal driving.
5th injector does work, but suffers from poor fuel distribution within the inlet manifold, for this reason it should not be used.
