After the engine drama of last tuesday, i am after a couple of 1 1/2" (38mm) rubber lined p clips.
I have looked on fleabay but cant find any this size. Does anyone know where i might find some?
CBS or your local hydraulics engineers?
rs components maybe
closest i can find in rs is 40mm
[Edited on 18/10/09 by 001Ben]
Demon Thieves have them but they aint cheap
Quick replys as usual
Cheers. 40mm should be ok
Make some yourself then you get the perfect size for your application. They're not difficult.
Phil
I have loads. How many would you like. Postage is all i require.
Nige
