Where can I find a 3.62 LSD diff (what models) and what should I be looking to pay?
Thanks,
Pete
I thought that was the standard ratio found in most 4x4 sierra rear axles?
Difficult to put a price on it, they've gone on eBay from £50 to £150.. I reckon you shouldn't have much trouble picking a good one up for
£100. If you hold out a bit longer you can bag a bargain and pick up a full axle for that much sometimes. To give you an idea, I picked up a good axle
complete with a good LSD, calipers discs hubs and shafts etc. for about £130 off ebay.
In fact I've seen axles with LSD's go for cheaper than a diff itself?! Helps when the letters LSD are not mentioned in the description..
So it's xr4x4 diff axle I'm after then?
Yeah, I don't think it's a rare ratio - but its the ratio I need!
i got one of a 4x4 sierra from ebay in November for £79 including the drive shafts
Just dont get one from a 2.0 DOHC XR4x4, as that will be a 3.92.
didn't the 1.8 cvh come with a 3.6?
