2lt pinto
popstar - 8/6/12 at 02:55 PM
right how far can i take my pinto engine it will be striaght out of a sierra is it worth it or better to get bigger beefyer engine
help this is the complicated bit for me many choises need to make
any body built a pinto to extream performace dose and dont welcome also
mookaloid - 8/6/12 at 03:49 PM
it's quite straightforward to get 200bhp or more out of a pinto but it would be way cheaper to get a zetec and put that in. If you were going to spend a decent amount of money then a Duratec is the way forward.
AllWeatherDan - 8/6/12 at 04:05 PM
Wot e Said
JAMSTER - 8/6/12 at 04:16 PM
june classic ford mag 2.2 pinto offset crank 93mm pistons zetec steel rods £1500 for the bottom end
the company below
http://www.naismithengineering.co.uk/
popstar - 8/6/12 at 04:18 PM
thanks guys lots to look into
mcerd1 - 8/6/12 at 04:37 PM
I've got loads of pinto tunning info, but a duratec will make more power for less cash
but I'm using a fairly big spec pinto in my build anyway
popstar - 8/6/12 at 04:53 PM
so duratec way to go if i can aford one
but if not pinto it is
snapper - 8/6/12 at 04:55 PM
130 bhp is simple
Injection head thin gasket FR32 cam
150 bhp a little more work on the head, valves, skim
More than that means more revs means better rods means pistons suspect
I have built a big spec pinto, cost £2000 all in all
My next build will be a Duratec
popstar - 8/6/12 at 05:03 PM
take it all for 2lt dur rather than the 1.3 from ka to make big and if so just found 2lt dura for not much on ebay but what would it take on top to spec up
andywilson - 8/6/12 at 05:14 PM
for me if you're wanting more than 150bhp from a pinto, cost wise youd be better putting a zetec in.
i have 155bhp with my pinto and without spending £££ its difficult to get much more
jacko - 8/6/12 at 06:01 PM
If you are stating from scratch forget the pinto and find a duatec i would think a tuned pinto would be dearer then a duratec and not much more power
I love my pinto and am happy with it but it would be a different story if i was starting again
Jacko
