Knob Problems!
Staple balls - 4/4/15 at 08:48 PM
Many years ago, I had a long, bendy knob that fitted nicely, but I sold it and ended up with a short, straight knob.
Anyway, problem is thus. I'm not sure what the best course of action is here, should I bend my knob, get a long bendy one again? something else?
coozer - 4/4/15 at 08:50 PM
Think you need a good clean up before you touch your knob!
Staple balls - 4/4/15 at 08:51 PM
That area hasn't had much use over winter, so my knob's a bit dusty
daniel mason - 4/4/15 at 08:58 PM
Who did you sell your knob too?
Staple balls - 4/4/15 at 09:01 PM
Honestly? I can't remember, one of those years I suspect.
daniel mason - 4/4/15 at 09:14 PM
I could do with a longer one! Any ideas?
Staple balls - 4/4/15 at 09:41 PM
I've heard a bit of gentle stretching can help
mark chandler - 4/4/15 at 09:46 PM
Get a grip please
Smoking Frog - 4/4/15 at 09:54 PM
Although posting pictures of your knob should be discouraged, I think you need some kind of extension.
Benzine - 4/4/15 at 10:03 PM
I'd stick the whole shaft in a vice and clamp it up really tight, then tug at the end until it's bent towards you more.
maccmike - 4/4/15 at 10:10 PM
I reduced my shaft as the knob stuck out too much
omega 24 v6 - 5/4/15 at 07:51 AM
Once seated I doubt you'll be able to reach your knob comfortably unless you kink it.
joneh - 5/4/15 at 07:59 AM
Looks like you'll catch your fingers on the dash unless a kink is added.
Don't want to end up with a sore hand.
Staple balls - 5/4/15 at 08:01 AM
So then, kinking my knob?
Vice + Brute force = happy? bit of heat perhaps?
Staple balls - 5/4/15 at 09:49 AM
Whee! I now have a short, bent knob, I think it might need more bending, but I suspect it'll feel crappy at that point, dash needs fitting and finishing before I do any more.
FWIW, stripped the thing down, clamped as low as I could without bothering the spring, heated until cherry and bent with a handy pipe.
maccmike - 5/4/15 at 03:40 PM
Oh, we were talking about gearknobs!
