Manifold R1 carbs - throttle bodies?
Rena - 24/4/17 at 08:57 AM
Hi,
I have a DanSt manifold with R1 carbs for my Zetec.
Thinking of going the throttle bodies route next winter. To keep the costs down it would be nice to use my existing manifold.
Any throttlebodies that will fit on my manifold?
SJ - 24/4/17 at 02:21 PM
The obvious answer is R1 throttle bodies.
Spacings should be the same so they should bolt straight up. As long as they have integral injectors you should be fine.
Stu
Rena - 24/4/17 at 03:33 PM
Stu
Are you sure?
redturner - 24/4/17 at 05:00 PM
Dan will make adapters to fit.....
Rena - 24/4/17 at 05:08 PM
Danst Engineering?
andygfc - 24/4/17 at 06:19 PM
I have some 2000 gsxr 750 throttle bodies
Bought to put on zetec, will need spacing, but is quite easy.
I've gone bike engine
£150 inc p
redturner - 24/4/17 at 06:49 PM
Danst Engineering?
Yes, thats his name, Dan Stanley.....
SJ - 24/4/17 at 07:10 PM
There are certainly R1 TBs that are spaced the same as R1 carbs. Not sure they are all the same though - later engines may be different.
Stu
Rena - 25/4/17 at 04:12 AM
Stu
I have found out R1 carbs are like 76-78-82,5 mm C/C.
The throttle bodies from a R1 after 2004 är paired, so it should be bodies before 2004.
[Edited on 25/4/17 by Rena]
Rena - 25/4/17 at 06:30 AM
£150 inc p
Pics?
Rena - 25/4/17 at 06:31 AM
Danst Engineering?
He can offer me a new kit and parts, but not any adapters that will make it fit.
lsdweb - 25/4/17 at 07:12 AM
I have a set of GSXR throttle bodies for sale - these are individual bodies so easily spaced. They are also single butterfly ones so no need to blank off second butterflies etc.
Link to for sale post
Wyn
