Engine Angle
geedle - 30/5/20 at 09:09 PM
Hi,
I'm putting a MX5 NB engine and box in a Haynes build (with MX5 mods). As I understand it, the mounting points for the NA and NB engines are the same. In order to clear, I think I'm going to have to angle the engine and box nose up about 2 degrees.
Is that cool?
Thanks, Geedle.
snapper - 31/5/20 at 08:39 AM
2 degrees is nothing, your engine mounts would settle more than that and your car pitches on the suspension by a lot more.
The Pinto engine was set in the Sierra at a steep rearward angle in comparison
designer - 31/5/20 at 09:43 AM
Up to 5deg is usual, and it also helps to rid the cooling system of bubbles.
geedle - 31/5/20 at 09:44 AM
That's what I thought. On a steep downhill, under heavy braking, the effective nose down angle would be much bigger. Thanks.
