How to reconize a 2l Pinto
ettore bugatti - 22/4/08 at 12:37 PM
I will be looking this week at a Ford Capri 2.0S, but how do I know that the engine is a 2 liter and not a 1.6?
Are there any reconizable differences between these two engines?
Mr Whippy - 22/4/08 at 12:38 PM
I think there is a '2L' cast in the side IIRC
ash_hammond - 22/4/08 at 01:08 PM
I agree with Whippy mine has 2.0 cast on the side.
Macbeast - 22/4/08 at 01:14 PM
According to Mr Burton -
"....Cortina blocks usually have the capacity in small numbers on the side - 16 and 20 respectively. Later Sierra blocks have 165, 185 and 205 "
HTH
Mr Whippy - 22/4/08 at 01:19 PM
oh yeah that's right it's written as - 2.0 forgot
ayoungman - 22/4/08 at 02:16 PM
205 block is the one to go for !
jollygreengiant - 22/4/08 at 05:16 PM
If its a capri and original then it will be (or should be) the older type pinto, so it should have a blue cam cover and that should have 2.0 embossed at the bottom over the Idler/oil pump pulley.
westf27 - 22/4/08 at 05:35 PM
weighsabout two ton and shaped like an anchor....I know
ettore bugatti - 23/4/08 at 07:27 PM
Ok, thanks!
That's exactly what I needed to know
