<<  1    2  >>
Author: Subject: Considering some real electronic jiggery pokery
coyoteboy
posted on 1/12/11 at 08:33 PM Reply With Quote
I've been considering the fact that my transaxle doesn't come with a torsen diff (dissappointing). My initial plan was/is to use the ABS rings to run traction control but that's sub-optimal. IT struck me that I could use an ESP module on some tiny secondary brakes (or even the primary brakes I guess) to force the open diff free-spinning wheel to transfer torque and match the other wheel speed +- some offset.
Has anyone given this a try. Clearly it would require reverse engineering the ESP unit electronics/signals and would only be needed on one axle.
Safety yada yada yes I know, and I'm not being flippant, I'm just aware of the risk/likelyhood and fairly good with electronics
Ninehigh
posted on 1/12/11 at 08:45 PM Reply With Quote
Sorry I've read this three times and you've lost me.
Are you trying to create traction control by locking either side rather than transferring power to either side?
mookaloid
posted on 1/12/11 at 08:52 PM Reply With Quote
thats the kind of thing that would work on an off roader - but on a racer wouldn't it just slow you down?
coyoteboy
posted on 1/12/11 at 09:04 PM Reply With Quote
Yep, grab the wheel with lost traction (so it doesn't affect vehicle speed negatively) and slowing it increasing torque to the other side (which would normally get none as the other is spinning freely). Won't slow the vehicle at all, it'll push both tyres to their slip limit (if controlled correctly). Essentially it will just need to work akin to ABS - only any wheel spinning too fast (requiring a reference speed - front wheel maybe) get's its brakes applied, forcing it to get back in line with road speed while the other gets more torque until it slips. Could have some issues with oscillation I guess, I've not planned that far ahead.
The biggest issue I see is getting that reference speed right, if you ahve that you can then tailor both wheel slipping to the ideal amount. I think it's fairly standard launch control on some cars these days.
[Edited on 1/12/11 by coyoteboy]
wylliezx9r
posted on 1/12/11 at 09:07 PM Reply With Quote
Isn't that what the call torque vectoring? Or is it similar to brake steer that the mp4-12c mac uses ? Im Sure getting it work properly would take some serious electronics.
George Best
coyoteboy
posted on 1/12/11 at 09:09 PM Reply With Quote
I guess it woudl be torque vectoring, not quite like brake steer as I wouldn't want to faff with varying brake forces in braking, I'd like that to be pretty plain. I'm guessing the ESP modules talk over CAN and getting the info on packet content is a pain, but the ESP modules are the only ones that allow increase in brake line pressure rather than decrease as with ABS as far as I know.
I'm up for serious electronics
designer
posted on 1/12/11 at 09:55 PM Reply With Quote
It's all gobble-de-gook to me, but good luck.
Xtreme Kermit
posted on 1/12/11 at 10:02 PM Reply With Quote
Couldn't consider doing myself, but it sounds plausible.
coyoteboy
posted on 1/12/11 at 10:23 PM Reply With Quote
As i say, it's do-able and when I find a usable ESP/ABS unit cheaply I just need to reverse engineer it to sus out how it works from an electro-hydraulic point of view. From that point I reckon I can fairly easily follow a simple control strategy to maintain a constant maximum wheel speed differential aross the back axle and hand the front-rear control over to the ECU (pull advance/spark cut). And of course ignore anything that happens under braking.
I'm sure I'll come across something that'll cause an issue but for now I'm just looking to see if anyone else has done it "DIY" style, as it's always easier to push forward from someone elses progress.
steve m
posted on 1/12/11 at 10:29 PM Reply With Quote
Could we have some pics of how your cars progressing,
now that you are re inveting the wheel
coyoteboy
posted on 1/12/11 at 10:36 PM Reply With Quote
Not really reinventing the wheel is it, it's called "hacking"
And yes, hit the www button at the bottom of my posts.
Glad to see the eternal pessimist has returned I don't know what the chip is on your shoulder, but I'm not playing the game for it.
speedstar
posted on 1/12/11 at 10:37 PM Reply With Quote
Pretty sure BMW use that technique for their Stability Management.
If you're overly harsh on it, you'll end up cooking your rear brakes (and then you have the new issue of a very fast rear on the entry of corners)
coyoteboy
posted on 1/12/11 at 10:43 PM Reply With Quote
Yes, massive brake wear is a concern, but since it's used in OEM's I guess that's really just a case of getting the control parameters correct and not being so damn right foot heavy I'll look into the BMWs, see if I can find out. The Saab ESP units sell for ~100 quid on fleabay - bit much for current funds after engine and box purchases and with xmas round the corner, but maybe in the new year. I'd like to get the scope/bus sniffer on a working car while it was activated but I don't have a car with it or the nuts to package all that into a car while someone else drives like a nut job
steve m
posted on 1/12/11 at 10:46 PM Reply With Quote
Oh, sorry, my mistake !!
and from your pics, you are building WHAT ??
A garage full of push bikes, and some weights, and an engine in bits
mmm, looks like your build plan, has a problem
coyoteboy
posted on 1/12/11 at 11:19 PM Reply With Quote
I've not finished planning the build. As mentioned in the past this is a self-design/build, something organic that will evolve as I investigate each area in turn and then finally come together - not a kit, not something laid out to begin with with all plans fixed in stone. I have the basics, I have a plan in my head and the rest is in my mind floating around while I consider the options. I know my powerplant, my drivetrain, from there I'm moving on to suspension - not that any of that bothers you, you just wish to take a stab, I know. As for the engine, yes there's an engine in bits while I strip it and check it's condition, get a few things replaced/repaired/coated.
I wasn't aware I had to follow your project planning schedules in order to do things that work, sorry. Jesus, get over yourself you moron. Anyone mentions doing anything different or isnt building something from a kit in 6 months and you think you have license to claim they're doomed to failure and incapable. Good sign of the insecure as it happens. Maybe you need to grow up a little before making comments.
Damn, I started to play the game You know I don't like making enemies on forums, but some peope do just come across as asshats, even when they're really nice in real life. I hope you are, for your sake. And yet again you've managed to turn an interesting informative thread into one about you and your schedules/belief - well done. Now please leave, it was going well without you.
hobbsy
posted on 2/12/11 at 12:23 AM Reply With Quote
I like the sound of what youre trying to achieve. Do you have a degree in electronics as it may come in handy (not dissing). The setup might take a while but its interesting
coyoteboy
posted on 2/12/11 at 12:37 AM Reply With Quote
Yep, I've got the required quals to do that side of it no problem (and bring too much of it home at night!) - I'm hoping that if I can do a bit of hacking around I might be able to make a cheaper (if slightly less effective) solution to the torsen equiv. For my box you're looking at £1k for the diff and no technical challenge, so I guess lumping in an esp module and a few months tinkering might create something usable a bit cheaper. It should be really transferrable to any open-diff RWD car, could easily make it open source in case people want to tinker.
blakep82
posted on 2/12/11 at 12:58 AM Reply With Quote
what transaxle is it?
it may not come with a LSD in standard form, but does anyone like quaife or tran-x make one?
personally (and i don't know how much you've looked into it, so you might have already covered it) i'd be looking into a quaife atb, or even a plate lsd from tran-x, if there is one. i'd be surprised if there isn't one tbh. i'm guessing its a audi transaxle or something? only other ones i can think of easily available is porsche...
i think the electronics to make a reliable and useful system will be very difficult to get right. as said brake wear would be worth thinking about, don't think it'll slow you down much, but i don't know, it wouldn't be my plan
i see from your photos its an audi 4.2 V8, i assume you're using the same transaxle, quaife have an ATB diff listed for the audi A6, with a 4.2 engine
http://www.quaife.co.uk/shop/search/results/taxonomy%3A824%2C621%2C50%2C67
any good?
ok, not cheap, but you know...
[Edited on 2/12/11 by blakep82]
________________________
coyoteboy
posted on 2/12/11 at 01:26 AM Reply With Quote
There's a few diff options available for the audi transaxle (01E) but as I say, you're looking around £1K for them and of course a full box stripdown (which hasn't long been done by the previous owner) which is (currently) outside of my planned expenses.
The electronics are really not an issue, I'm more than aware of the problems involved in creating vehicle electronics and all the protection and environmental/noise issues related to it. I have built a fair few in car systems (and been bitten by a few of the bugs!) so that side of it I'm fairly comfy with achieving, it's the elec/hydro interface item I've no experience with hence the request for any similar work done. I know electronics are not everyone's cup of tea, especially not on cars of a very simple format, but while I was challenging myself to something mechanically taxing I felt the project was lacking in electronic challenge and since this can be done as a side-project and the car run without it seemed like an interesting add-on (or way of locking wheels and spinning lol)
Autosri
posted on 2/12/11 at 01:45 AM Reply With Quote
my bmw has something like this sort of trying to mimic an lsd and to be honest it sucks its very unpredictable sometimes it wont react quick enough and lets it slid sometimes it corrects it and it bogs the car down and most of the time it slips then catches it and you start understeering
although its more complicated than your thinking of doing as it compairs all the wheels speeds along with the steering angle to work out if it thinks its sliding or not
personaly i would look at getting a proper diff as when i want to play it ets turned off and just use the open diff
blakep82
posted on 2/12/11 at 02:55 AM Reply With Quote
well, 2 very different options, 1 easier but expensive, the other cheaper but more complicated i'd say. its a difficult choice i think personally.
will be an interesting project! will it be more of a mod, as in build the car, get it legal (if needed) and add it later? or is this a main consideration from the start?
i'll be getting an LSD for mine when i can afford it and the car's done (or as near as...)
scudderfish
posted on 2/12/11 at 06:47 AM Reply With Quote
Thinking about it you may not need a reference from the front. Think of it this way :- The diff is to allow the wheels to turn at different speeds when cornering. The greatest difference is when the car is turning the smallest radius it can. This gives you a relative maximum. If the relative speed difference of the wheels exceeds this, the fast one must be spinning.
https://vetuner.co.uk
MkIndy7
posted on 2/12/11 at 08:25 AM Reply With Quote
There may already be some code available like this for the Megasquirt, is that not how it does traction control i.e the crank cannot possiby accelerate at that rate if there is any load on it and then backs off the ignition timing.
Also if your looking to do it all electronically rather than delving in the the electro/hydraulic interface, I'm sure I've seen electronic rear calipers or handbrake calipers for new VW's or something similar on eBay
I'm pretty sure this idea of braking the spinning wheel on an axel is how my mates S3 manages on snow otherwise with 2 open diff's and the way it transfers power you'd very easily get stuck!.
stevebubs
posted on 2/12/11 at 08:49 AM Reply With Quote
VAUXHALL OPEL OMEGA BOSCH ABS PUMP ECU 0 273 004 207 | eBay
VAUXHALL OMEGA ABS UNIT PUMP ECU 0 273 004 207 DY 94-03 | eBay
[Edited on 2/12/11 by stevebubs]
coyoteboy
posted on 2/12/11 at 11:45 AM Reply With Quote
I will have the option for electronic disabling of course, but I suspect if it's done right (which will be no mean feat) it would operate just like an LSD. There could be two stages of operation - one to just keep the wheels within a certain ratio and one with the squirt traction control included to limit both-slipping conditions, but the latter removes more of the fun but might be helpful with new drivers to it.
will be an interesting project! will it be more of a mod, as in build the car, get it legal (if needed) and add it later? or is this a main consideration from the start? i'll be getting an LSD for mine when i can afford it and the car's done (or as near as...)
Yep, definitely more of a mod but I don't want to design the possibility out at the start - I think I'll probably end up with custom uprights but I need to keep the ABS sensor locations in mind for this.
You're right there - I could possibly ignore the actual car speed. Something niggling in the back of my head last night suggested I may need it for identifying specific "non activation" times.
Yes, the squirt has both wheel-speed analysing traction option and rev rate limiting as an option, the problem with both of those is they limit power to all wheels rather than just the slipping one, but I think that needs to be incorporated along the way.
I'll have a look at that, thanks. I was looking at one unit and it seems the solenoids driving the valving are seperate and attached to the PCB, while the sealed hydro section could remain in place. I could possibly remove the PCB and replace it with my own by careful removal of the solenoids.
<<  1    2  >>
