black fingernail
| posted on 11/6/10 at 06:46 PM |
Cheers bud. I'll let you know what I find. Now I know this manual has the flash codes somewhere....
Madinventions
| posted on 12/6/10 at 12:26 AM |
Found this online:
switch ignition on
immo lamp illuminates for three seconds under normal conditions
if it illuminates for one minute, wait and count flashes
the flash code consists of two groups of flashes (one set for each digit of the code) so * ** will be code 12
if you mis-count don't worry they are cycled ten times - or just start again
if the LED flashes rapidly the vehicle is immobilised
codes and definitions are:-
11 - immo control module not connected (wiring, reader coil connection, control module connection etc)
12 - immo control module not working correctly (duff immo module)
13 - key code not received or key programming failed (faulty key or key obscured)
14 - partial key code received (faulty or obscured key)
15 - key not programmed into immo module (reprogram or try different key)
16 - faulty link between immo module and ECU (wiring fault)
21 - less than three keys programmed (program more keys as necessary)
22 - ROM error - no ECU ID stored (duff ECU)
23 - ECU ID mismatch (duff ECU)
31 - code transmission error between immo control unit and ECU (wiring or ECU programming error)
32 - ECU/immo control unit comms - no response from ECU (wiring, immo control module)
33 - comms error (wiring, duff ECU or duff immo control unit)
Also see here: Linky
Ed.
View my band website:
http://www.shadowlight.org.uk
black fingernail
| posted on 13/6/10 at 01:23 PM |
Hi there got it running.
Its strange if you havent got fuel through it it wont spark.
Here is a link of it.
http://www.youtube.com/watch?v=RDznw17Phs4
Thanks for all your ideas help a great lot.
All i'm after now is s/s manifold straight out piped just missed one on ebay.
Madinventions
| posted on 15/6/10 at 01:58 PM |
Brilliant - well done!
Post some more updates when you get out on the road?!
Ed.
johnH20
| posted on 15/6/10 at 03:48 PM |
Congratulations Black Fingernail! I will be trying the same thing myself in a couple of months so please don't forget how you did it!
