Strontium Dog
| posted on 14/8/10 at 10:48 AM |
quote: Originally posted by MikeR
My experience was speaking to a professional powder coating company when i was looking at doing my chassis, they "confessed" that powder
coat isn't really designed for outside use and they wouldn't recommend it for long term protection.
There are primarily two types of powder coat, Epoxy and Polyester. You need to use the right one for external use. Epoxy flows out better and gives a
superior finish but does not like being outside in the elemrnts. Polyester is more orange peely but is more suited to external use.
Make sure your powder coater is using the right powder for your application
dinosaurjuice
| posted on 14/8/10 at 01:42 PM |
quote: Originally posted by interestedparty
quote: Originally posted by dinosaurjuice
although it will cost more
Any idea how much for a chassis?
I paid £300+VAT for my MEV Rocket chassis, worth every penny.
Piccy:
will
Valtra
| posted on 14/8/10 at 09:44 PM |
powder coat seems fine to me still looks good after several years, but car is not actually outside that much of the time . As said before you need
good prep., and FFS don't brush paint the chassis, 9 times out of 10 it looks pants. I've seen dozens of quite high spec well built cars
ruined by brush marks and once the car is built you are stuck with it unless you strip the whole car down and start again , so unless there are NO
exposed bits at least spray it . Having said all that, Smootherite can be brushed quite well but it's too big a risk , 4 or 5 rattle cans could
easily do a whole chassis if you don't have access to a compressor
"If it looks like it works and it feels like it works, then it works"
JF
| posted on 15/8/10 at 10:32 AM |
Yeah but a layer of spray paint (especially rattle can) is really easely damaged. Personally I'd want a more durable finish.
I know a guy that had his BMW motorbike bedliner sprayed. Quite rough matt look, and just as durable. He had the frame, tank and panels sprayed. And
it is developed for rough outdoor use in pickup trucks.
From what I've heard it ain't cheap, but to me it would be worth considering.
Neville Jones
| posted on 15/8/10 at 12:01 PM |
After years of trying all sorts of methods. the best I've come up with is as follows:-
Degrease meticulously to a very clean condition.
Apply zinc phosphate primer, 2 coats letting fully dry in between.
Top coat of 2 pack paint, preferably a polyurethane, as it doesn't get as hard and brittle as the others.
I've tried Galvafroid, and it's fantastic, but doesn't tend to 'stick' to the base steel. If chipped it reveals a bright
and shiny base, but it does tend to chip easily, independant of what's on top.
My local powder coater will not coat bare steel, he insists on zinc passivate underneath first. He says this is from past experience, and too many
jobs returned 6 months on with peeling due to rust formation underneath.
Marine epoxy mastic type paints are great, after all they keep big ships rustless, but are not too user friendly, and are meant to be applied fairly
thick, which tends to a poor finish.
Nev.
Valtra
| posted on 15/8/10 at 01:26 PM |
Frosts catalogue has a whole range of different paints (if you must) that look suitably tough . not cheap , but as the saying goes don't spoil
the ship for a hap'eth o tar.
metallisation
| posted on 22/9/10 at 03:41 PM |
Hi All
I work for Metallisation Ltd who are a thermal spray equipment manufacturer.
Thermal spray was mentioned above as an alternative for galvanising and much of what was said above is correct with regard to long term protection,
and thermal spray not giving the same distortion problems which you may get with galvanising.
If anyone wants any advice on this process or the equipment should you wish to set up yourselves, or for companies who may be able to carry out this
operation for you in your local area then please do not hesitate to contact me on the following email or phone and I will try to assist
07595 651643
iainblacklock@metallisation.com
p.s. you can also spray other metals such as copper, bronzes, brass, tin/zinc (which polishes back really well) for decorative finishes which can then
be polished back and aged if necessary - just an idea for you :-)
Regs
Iain
[Edited on 22/9/10 by metallisation]
