posted on 25/3/11 at 09:31 AM |
Book design uses Cortina ball joints which are a substantially different design. However, I have seen a lot of wishbones with a very similar design
to yours, though typically using 5mm plate.
quote: Originally posted by ashg
quote: Originally posted by MikeRJ
Bruise?
name of his car
I guessed that, just seemed a very odd name!
[Edited on 25/3/11 by MikeRJ]
posted on 25/3/11 at 09:34 AM |
I guess it's called the bruise 'cos it's black and blue!
Grimsdale
posted on 25/3/11 at 09:55 AM |
3mm is definitely too thin, my replacement front wishbones were of a similar design but with 6mm plate.
splitrivet
posted on 25/3/11 at 09:56 AM |
Very reminiscent of moggy minor trunnions (ask yer grandad). Which would be fine till you parked the car and were just walking past the front of it
and the front wheel would fall off, but never heard of them letting go when you were motoring.
Bob
RichardK
posted on 25/3/11 at 08:35 PM |
Not to worry boys got it fixed today
More pictures here
Love Rich
xx
Gallery updated 11/01/2011
HowardB
posted on 25/3/11 at 08:43 PM |
I am a composites eng, not a metallurgist but, pics 002 and 003 show what I believe to be fatigue failure on the left hand side of the picture as you
look at it.
Welded might get you through the summer,....?
Howard
paulf
posted on 25/3/11 at 09:03 PM |
That is not as the original book design, on the original Cortina ball joint there is 4 mounting bolts with 2 in the same place as photo and another 2
inboard of the ball join and at an angle on the mounting plate to match the ball joint plate.In the photo the plate is going to flex between the ball
joint and tube ends and eventually break.
The repair may be ok for a while but what about the other wishbone? is that going to break some time soon as well?.
I would make a pair of new wishbones either with Cortina ball joints or the maxi ones and extend the tubes to go past the ball joint centre line.
Paul
More pictures here
Love Rich
xx
zilspeed
posted on 25/3/11 at 09:15 PM |
Sorry, but there's so much about that which I don't like.
Look where it fails.
Right where the flat plate first goes from being supported to being unsuppported.
So, right where you need it to be at its strongest, it's at its weakest.
Not good.
It all depends on a bit of 3mm plate which due to the continual suspension travel is always having a bending force being applied to it.
Add to that, a balljoint in good order will always but always have a considerable amount of resistance to articulation.
The minute it doesn't, it's ready for replacement.
The balljoint is continually doing a Uri Geller on the plate with frankly inevitable results.
Considering all that, I just wouldn't be happy with that design at all.
I'm tempting to speak to our structurall engineers about this on monday.
A more obsessive bunch of people you will never find.
I'm pretty sure they wouldn't have signed off on such a design.
Please tread carefully and consider whether you're truly happy about using this wishbone again.
austin man
posted on 25/3/11 at 09:27 PM |
I think that the wish bone is seriously at risk of further failure, the plate will have been hammered back into shape futher weakening it. I would
look to having a new one made with a minimum of 5mm plate. You came close to having a near death experience I wouldn't want to chance my luck
twice
SeaBass
posted on 25/3/11 at 09:30 PM |
Richard - I take it your just trying to wind people up with those repair pictures? IMHO you should not drive the car with those wishbones as they are,
let alon repaired. They way you've welded them has now created a Heat Affected Zone exactly along the line of flexing. The original welds
created such a zone which is what I think caused them to fail in the first place - HAZ and work hardening on a critical component = NOT GOOD.
JC
ashg
posted on 25/3/11 at 10:28 PM |
the haynes design is a fair bit better than those. for a start the plate is 5mm and it has a bend in it just behind the line of the tubes. also the
plates have tags that sit into the tubes you then crush the tubes down on to the plate and weld the ends up. the other thing is that the tags that go
into the wishbone tubes are on the same line as the bend in the end of the plate but not bent putting them on a different plane.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
