omega 24 v6
| posted on 15/7/11 at 09:36 PM |
Firstly a big thanks to Phil for his help.
It looks like the problem was of my own doing. I took the covering off of my loom to find that in the dim and distant past I had actually grounded the
vr -ve to the ecu ground ( externally) this coupled with the incorrect vr polarity was causing the problem. Swapping the vr wiring at the ecu ( which
is what I did and thought would cure it) did actually give it the correct polarity BUT because it was grounded externally ( and I changed the wires
internally) it now meant the vr+ was now grounded ( if you see what i mean).
I still have the induction clacking noise ( going to fit a filter box and filter a some point) but the timing is now advancing as it should and no
acceleration flat spots at all. Great.
Again thanks Phil and everyone else for their help.
daviep
| posted on 15/7/11 at 09:59 PM |
Happy days
Glad you got it sorted.
