stevegough
| posted on 13/4/12 at 06:48 PM |
Ok, Ash - I think we can put this one in the 'Good Fail' classification, so well done! Shame about the coilovers - that shouldn't
happen? - How have other Exocet IVAs fared in this respect?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Daddylonglegs
| posted on 17/4/12 at 11:16 AM |
Well done Ash, as already said, that defintiely qualifies as a good fail . Lets hope it's sorted soon and then it can all be put behind you
(just like most of the traffic on the roads )
loggyboy
| posted on 17/4/12 at 11:46 AM |
quote: Originally posted by ashg
dominator style headlights also provided in the kit failed. the beam pattern was quite simply put bloody appalling (looked at it myself) they also
kicked up slightly the wrong way. also the suggestion to rotate the passenger side one by ten degrees so it kicks up was a non starter as it clearly
states in the manual that it is not permitted.
I think the idea is to rotate both lenses, not the acctual light. However, its still not an ideal situation and will leave me considering other
options as I wanted the neat look of dominators, but it seems they are lacking quality.
40inches
| posted on 17/4/12 at 01:17 PM |
[Edited on 13/4/2012 by ashg]
Having fitted Dominator's myself, I have just been in the garage to check them, bit of a relief to find that the dip beam pattern is flat and
very well defined. Thankfully.
