plugy1972
| posted on 23/4/12 at 06:16 PM |
is anyone still any closer to solving the my issue with the indicator wiring
snowy2
| posted on 24/4/12 at 06:47 AM |
to be honest i think we have answered it......
so explain exactly what you want.....
Indicators + 1 or 2 warning lamps?
hazards and warning lamp (the 2 above or a separate one)
Are you trying to nail an existing car loom into your car or have you started from scratch?
Are you using a hazard switch? or are you trying to use a general DPDT switch (why if you are, to save a few quid?...weird as using a hazard switch is
so easy and since you dont seem to understand electrics why give your self extra hassle)
sometimes you are the pigeon, most of the time the statue.
snowy2
| posted on 24/4/12 at 07:47 AM |
here is a sketch of a circuit something like what you are using....i think.
does this help? i am a bit confused what you need......
snowy2
| posted on 24/4/12 at 08:13 AM |
Oops the hazard warning lamp would come on with indicators......@if it was connected to pin 49 and not 49a that should fix that problem.
er nope....the relay needs to be on the live side of the switch. do you know its so much easier with a proper switch.
[Edited on 24/4/12 by snowy2]
tendoshingan
| posted on 24/4/12 at 12:10 PM |
Yep connect it in parallel to 49a with one diode going toward the connection to prevent the hazard dash light coming on when the indicators do.
plugy1972
| posted on 24/4/12 at 01:43 PM |
what size diode and from the drawing(i didnt do) i cannot figure out if the wire crossess over or connected together where it looks like it is teed
if.
ReMan
| posted on 24/4/12 at 02:47 PM |
OK here's my last shot!
  hazbad2
This is using your diagram (although I dont like it) I've just added in the pin numbers on your switch as per your very first post (use 1+2 or
5+6 it makes no difference)
All you need to add in is the 2 diodes, which I would connect at the back of the switch
The diodes assuming your using normal lamps 6A should do, something like this
http://mobile.maplin.co.uk/module.aspx?moduleno=46413
Then wire in you hazard lamp as shown
[Edited on 24/4/12 by ReMan]
www.plusnine.co.uk
plugy1972
| posted on 24/4/12 at 02:50 PM |
This is my diagram indicators work seperatly, hazzard works seperate, i have two indictor directional lamps that flash and work, but i dont have a
hazzard light, there is one on the steering colum but i want one on the dash to mach the other lights, working with the DPDT switch so where and how
do i add a hazzard lamp on the circut to illuminate when hazzard switch on?someone mentioned a dioode if so where does it go and what size?
plugy1972
| posted on 24/4/12 at 02:53 PM |
will get the diodes and try your help is much appreciated and all those others that help cheers.
plugy1972
| posted on 25/4/12 at 02:06 PM |
on way to maplins to get the diodes to fit so here goes
