James
| posted on 4/12/02 at 05:03 PM |
quote: Originally posted by Viper
you don't need undercoat or laquer with smoothright. (hammerright smooth) thats the why i used it..
Actually the spray can does appear to suggest with ally you should use their (special metals?)primer before.
But I take it you think it's ok without?
Thanks,
James
Viper
| posted on 4/12/02 at 07:01 PM |
you would normaly need the undercoat to etch into the metal, but your diff being a casting the surface is not smooth so the paint will stick... mine
did...
stephen_gusterson
| posted on 4/12/02 at 10:29 PM |
so hamerrite is working for you Viper?
After using it a bit I have decided its crap.
Its like painting with epoxy glue. It chips off and it streaks. It also takes 6 weeks between coats. According the the website, if an objects too hot
to touch, its too hot for hammerite.
not very good really.
I used it on my bell housing and engine brackets, and I think next time I will use something else.
atb
steve
[Edited on 4/12/02 by stephen_gusterson]
Viper
| posted on 4/12/02 at 10:38 PM |
I have used smoothrite on engine blocks in the past paint stayed on didn't even fade and it was easy to keep clean....go figure.
