<<  1    2  >>
Author: Subject: Any MegaSquirt experts?
coyoteboy
posted on 29/5/14 at 07:00 PM Reply With Quote
FWIW you're better running a Req_Fuel that gives you VE values from 0-~230 not from 0-100, this gives you better resolution around idle and tricky spots.
Don't concentrate on numbers, but get some decent starting values from a friendly squirter.
Adjusting 1sq Sim to 2sq alt doesn't change the fueling on each squirt, but adjusting to 4sq alt or 2 sq sim would halve it, but then there's an offset due to the injector dead time - if you don't have that tied down accurately the switch will yield a fairly large change in each direction near idle.
shaunod
posted on 14/6/14 at 09:11 PM Reply With Quote
'BKLOCO' .... send me your Tuner Studio project and I will take a look for you. 2.0 Zetec is usually pretty simple .. sounds like you have a primary setting wrong. U2U me and I will send email address.
<<  1    2  >>
