<<  1    2    3  >>
Author: Subject: Mk R1 Clunky Gears Help?
jakeob
posted on 8/4/12 at 02:39 PM Reply With Quote
The lads at MK confirmed its got a TRT prop,, but do wonder if it failed in some way
ReMan
posted on 8/4/12 at 05:21 PM Reply With Quote
"Also if i try to rotate the basket back and forth it moves maybe 4-6mm while the rear cog stays still. "
I'm not familiar with the R1 clutch, but this souns very much like I was describing.
Can you post a pic?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jakeob
posted on 8/4/12 at 05:39 PM Reply With Quote
Yes just took some pics
need to see how to post them
jakeob
posted on 8/4/12 at 05:57 PM Reply With Quote
i think this is it http://i1177.photobucket.com/albums/x360/370nel/R1%20clutch/IMG_0810.jpg
ReMan
posted on 8/4/12 at 09:20 PM Reply With Quote
Looks very similar
blade clutch
blade clutch
If it is then as yu can see when you pull the basket there is a shock absornber in it so some movement is normal.
Double check though as per my pic that the splined centre of the drum casting is (very) tight
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
<<  1    2    3  >>
