RobBrown
| posted on 6/10/13 at 04:55 PM |
MJ Map, to try and replicate it unconnected
The spark plugs are interesting. the first two plugs seem to indicate not complete burn\rich as they are oily, but the rear two seem to indicate lean
as they are light in colour, not oily at all.
Wonder whether it is linked to the first two also being the ones with the low compression.
Have blasted through the pilot jets and holes with carb cleaner, but doesn't seem to make any difference to the cutting out off choke. However
it will now start and run if the throttle is feathered but still high AFR.
