Author: Subject: Castor - Negative or Positive?
speedyxjs
posted on 6/11/08 at 11:17 AM Reply With Quote
Looking at Dave Andrews page i saw this:
Do i want Negative or Positive castor?
mookaloid
posted on 6/11/08 at 11:21 AM Reply With Quote
Negative for self centering
No positive --- the drawing is wrongly labled
Edit: Ok it should be as in the one labelled negative even if it is labelled incorrectly
[Edited on 8/11/08 by mookaloid]
mikeb
posted on 6/11/08 at 11:23 AM Reply With Quote
assuming the king pin line is the front wheel, negative castor angle.|
The more king pin inclination hence castor angle the more mechanical trail which gives you self centering hence steering stability.
speedyxjs
posted on 6/11/08 at 11:33 AM Reply With Quote
Ok. How much do i need and how will i measure it when fitting brackets?
posted on 6/11/08 at 11:47 AM Reply With Quote
The drawing is wrongly labeled
posted on 6/11/08 at 11:49 AM Reply With Quote
posted on 6/11/08 at 11:57 AM Reply With Quote
Not often Dave Andrews gets it wrong but this how it should be.
Negative caster is used on some front wheel drives -- Mainly BL Minis to give stability while accelerating.
Positive caster for RWD car -- light cars need more than large cars. Rescued attachment fronta.gif
posted on 6/11/08 at 12:04 PM Reply With Quote
http://crcc.org.uk/rc-technical.php
http://en.wikipedia.org/wiki/Caster_angle Rescued attachment positive-caster.jpg
Alan B
posted on 6/11/08 at 12:17 PM Reply With Quote
Actually isn't king pin inclination the angle when viewed from the front?
posted on 6/11/08 at 12:35 PM Reply With Quote
That depends on what type of driving you intend doing. Anywhere between 0 to 7 degrees. Most aim for about 5 degrees. It's the shape of the top wishbone and not the wishbone brackets you need to be overly concerned about. Obviously the brackets need to be to the same dimensions either side (within tolerance).
Phil
iti_uk
Builder
Posts 163
Registered 13/10/08
Member Is Offline
Photo Archive Go!
Building: The KLMX-5 ('97 MX5 w/Mazda KL 2.5L V6)
posted on 6/11/08 at 01:09 PM Reply With Quote
You're thinking of camber. Castor is, as above described, the angle between the kingpin and the vertical plane, +ve if "tilted backwards", -ve if "tilted forwards".
You want +ve castor and -ve camber.
Chris
g.gilo
posted on 6/11/08 at 03:06 PM Reply With Quote
caster kpi
hi
i get a bit woried when you read a post like this one, some of the guys giving advice and i assume building a car seem to be a little short of the correct terms / skills ?
looking at the car from the front, draw a line through the centre of the top and bottom ball joint and that is your king pin inclanation, castor is when you look at the same line from the side of the car. simple. graham.
matt_claydon
posted on 6/11/08 at 06:09 PM Reply With Quote
Originally posted by g.gilo
hi
This is correct. KPI is not necessarily the same as camber though as that depends on the geometry of the hub/upright. This diagram show zero camber but considerable KPI:
Alan B
posted on 7/11/08 at 08:51 PM Reply With Quote
Chris
Nope...I'm not.....definitely thinking of KPI..which is definitely measured in the front view (as is camber also)...I don't disagree with your definition of castor.....just being clear about KPI that's all
[Edited on 7/11/08 by Alan B]
posted on 8/11/08 at 09:09 AM Reply With Quote
(1) Drawing on Dave Andrew's site is WRONG with regard to caster .
(2) In positve caster the virtual kinpin line tillts backwards when viewed from the side as in the drawing below
(3) RWD drive cars normally need positive caster
(4) With ball joint suspension to get positive caster the upper ball joint centre should be aft of the lower ball joint's centre.
If in doubt check the above in any authoritative automotive text book.
[Edited on 8/11/08 by britishtrident] Rescued attachment positive-caster.jpg
posted on 8/11/08 at 09:25 AM Reply With Quote
Nice illustration 100% clear
Syd Bridge
posted on 8/11/08 at 11:05 AM Reply With Quote
I've kept out of this so far, but,
Amen to that brother!!!! Some of the noisiest on this forum have the least proper knowledge. And worst of all, rely on that cursed Wikipedia for their misinformation, or what they read on other similarly misinformed forums.
Castor...is ALWAYS POSITIVE. ie. Kingpin or effective kingpin angle leans back at the top when viewed from the side. Negative castor is suicidal. Does the opposite of self centering.
KPI...Is always positive. But can be zero on occasions. ie. Viewed from the front, the effective kingpin angle leans in at the top. Never negative, for the same reasons above.
Cheers, Syd.
Rod Ends
posted on 8/11/08 at 02:51 PM Reply With Quote
Positive camber!
