New Topic New Reply
Author: Subject: Advice and Opinion (Pics)
Nosey
posted on 15/11/08 at 10:30 AM Reply With Quote
Hi All,
Getting close to finishing the chassis and am wondering if people could look over these pics (apologies for the poor quality). Car is for hillclimbs so engine is moved over to passenger side & back as far as I could, English axle, ST bodywork. Any advice on glaring oversights or basic errors? All opinions welcome.
[Edited on 15/11/08 by Nosey]
MakeEverything
posted on 15/11/08 at 10:41 AM Reply With Quote
Looks ok to me.
Kindest Regards,
Richard.
prawnabie
posted on 15/11/08 at 10:42 AM Reply With Quote
Not that im an expert but will you need extra bracing around the rack mounts?
Shaun
lsdweb
posted on 15/11/08 at 10:46 AM Reply With Quote
Rear diagonal in the cage? Mandatory in the UK - Irish regs ae usually tighter again!
Wyn
MikeR
posted on 15/11/08 at 10:47 AM Reply With Quote
I'd strengthen your rear trailing arm links with a gusset. They have been known to break.
No diagonal in your rear hoop.
Rear stays look thin (is it all to MSA spec?)
Can't see seat belt mounts
Steering rack should have some triangulation across the width of the car
I'd also build in some ajustability to the steering rack mounting points to dial out bump steer.
Add top triangulation to the engine bay as its for racing.
Read up on the cymitrics / ausie chassis mods to strengthen the car. You can add strength for very little (or in some cases) no weight gain.
Put your shock brackets at the front on the outside of hte chassis rail (makes them slightly more upright).
Cap your tubes to stop water getting in.
Cant really see - but make sure you've got some diagonal steel in the transmission tunnel in case the prop breaks.
Weld in the triangular bits from the top of the rear shock mounts to the 3/4 diagonal going backwards to the rear.
I'll stop now (cause i can't see anything else). It looks good by the way and fantastic sized garage
[Edited on 15/11/08 by MikeR]
prawnabie
posted on 15/11/08 at 10:53 AM Reply With Quote
Ah yeah
The trailing arm brackets def need some support on the outer half, they will bend and snap in not time - I have had this problem on all 4 of mine!
Nosey
posted on 15/11/08 at 11:10 AM Reply With Quote
Thanks for the quick replies lads.
All good points which have been taken on board, but the only thing that isn't planned/has me worried is the trailing arm supports. Is this a matter of welding some plate (3mm to much?) where I have the yellow in the pic:
MikeR
posted on 15/11/08 at 11:57 AM Reply With Quote
No.
I'll explain in a mo if i can find a picture.
(edited)
Sod the picture.
The trail arm bracket is half on the 1" steel and half floating in mid air. The half that is floating in mid air should have a gusset on its outside edge to the edge of the 1" steel tube closest to the front of hte car.
Imagine trying to push the outside of the car side of the bracket towards the front of the car. It would bend about the weld onto the 1" tube. By putting the gusset from the outside edge of the bracket you help stop this.
Personally, i've used a 12" bit of box cut in half and drilled for brackets. Adds more weight but it aint going to bend and break.
Nosey
posted on 15/11/08 at 12:16 PM Reply With Quote
Ah yeah, MikeR, gotcha, hadn't thought of that, will add some gussets here. Thanks for the help
Liam
posted on 15/11/08 at 09:19 PM Reply With Quote
Big shame you couldn't have done the exhaust manifold to allow the engine bay top diagonal on the exhaust side.
Add a couple of diagonals from the lower-rear font-wishbone bracket nodes up to the top-front corners to triangulate the side of the front suspension 'box'.
Looks good.
Liam
New Topic New Reply
