Author: Subject: TRT propshafts?
GregMcN
posted on 2/12/08 at 10:42 PM Reply With Quote
TRT propshafts?
Has anyone retro fitted a TRT propshaft - just wondered how much difference they make. I have a quaiffe reverse box so would only be the rear part of propshaft.
Currently the gearchange in the 1st 3 gears is pretty harsh though surprisingly better when cold than hot??
Thanks Greg
skippad
posted on 3/12/08 at 12:33 AM Reply With Quote
i changed to trt prop a few months ago, had same problems as yourself.
Now a lot smoother through 1st.2nd gears, still a little bit clonky but a big improvement and less vibration.
Dave
paublo999
posted on 3/12/08 at 11:49 AM Reply With Quote
as skippad - wont change it to being like a car, but it is a little bit less "harsh".... not much though. Never noticed it on the track, but i did notice it more on the road...
My videos http://www.youtube.com/user/ninjabogeyracing
skippad
posted on 3/12/08 at 12:21 PM Reply With Quote
Hello Paul
Did you get your "safe mode" problem sorted?
Did you change your sump.
Any other problems?
Dave
If u noticed in my post, i've got another project on the go (bloody idiot) while me zzrMK's winterised.
bedlamage
posted on 3/12/08 at 12:50 PM Reply With Quote
TRT
I changed mine and got rid of the Westfield r/box ( which is sh#t ).
I have seen a noticable differance, no vibration, much less shunting, smoother changes and quicker pick up on the acceleration.
I have a straight tho TRT prop manufactured by Bailey morris with high speed balancing and forged flanges for greater strength and reduced weight. Can't recommed them enough!
adithorp
posted on 3/12/08 at 12:55 PM Reply With Quote
I've had a TRT prop from the start so don't have a direct comparison but... Someone once described the difference to me as like hitting something with a rubber hammer instead of a normal one. It still hurts if your thumb's in the way but doesn't mark the metal.
adrian
http://jpsc.org.uk/forum/
charlierevell
posted on 3/12/08 at 08:36 PM Reply With Quote
I'd use one.... my box has just gone because i havent got one already fitted! Its going to cost the same as the prop and its the 2nd time its happened in a year!
Tango orange is an 'IN' colour!!
