Author: Subject: which ratio lsd diff??
t16turbotone
posted on 7/12/08 at 03:22 PM Reply With Quote
hi folks, your help/jugdement is needed,
ok ime running a rover t series turbo engine, lt77 gearbox and a sierra 2.0ltr diff, i want to change diff for lsd unit, which ratio diff should i go for...thanx
posted on 7/12/08 at 03:29 PM Reply With Quote
people will need your tyre size to do any calcs. Myself, id start with a 3.62 LSD because thats the cheapest, and if you want to make another ratio you'll need the basic LSD anyway. There is a 392 but i think that would be too short.
TOO BADD
posted on 7/12/08 at 04:59 PM Reply With Quote
I had a 3.62 lsd in mine with a 200 hp XE but the gearbox is a BGH with longer ratios and 15 inch wheels. I changed to a 3.92 lsd and found it far better as the wheels are fairly large and the ratios longer.
I would def go for a 3.92 if you can find one.
madteg
posted on 7/12/08 at 05:56 PM Reply With Quote
I am running a 3.62 with 2.0L type 9 and 15" wheels, seems ok to me, top speed 130 MPH. But need longer first gear.
Paul (Notts)
posted on 7/12/08 at 06:15 PM Reply With Quote
I have a LT77 and use a 3.62 diff ( 17inch wheels)
This gives me 60mph in 2nd gear at approx 6100 rpm.
used to have a 3.92 but althought better acceleration throught the gears they ran out too soon.
Paul
mcerd1
posted on 9/12/08 at 09:19 AM Reply With Quote
here's the link to a good gear calc (assuming you don't have it already)
http://locost7.info/gearcalc.php
