Author: Subject: Windscreen
mad4x4
posted on 18/12/08 at 07:56 AM Reply With Quote
Windscreen
What wiper Motor Do I USE ?
What Heater do I use ?
Can MK Indy.
Scot's do it better in Kilts.
Mr Whippy
posted on 18/12/08 at 08:55 AM Reply With Quote
Car builder solutions supplies all the things you need for this. Use a cable drive wiper for a 7. Best to fit a hood too if you want to see the benefits.
myeates
posted on 18/12/08 at 09:07 AM Reply With Quote
i used a mini wiper motor and heater in mine should be easy to get hold of
mark
posted on 18/12/08 at 10:01 AM Reply With Quote
I also used a mini wiper setup. Heater-wise I'm still fabricating one out of an oil cooler and a lightweight fan....
zetec
posted on 18/12/08 at 10:21 AM Reply With Quote
Forget the heater. If you need for SVA forget the screen till you have passed. I fitted the screen after using a mni motor and shortened rack. Also check out the best sweep pattern, mine park with the blades in front of the driver. Used very short wiper arms from Dax.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Rob WM
posted on 18/12/08 at 11:55 AM Reply With Quote
SVC also provide wiper set ups which I think are cheaper but you should chck. They will also cut etc all the cable operation for you if you give them the measurements. I intend to use CBS for the heater as their product seems better. Mini option also sounds interesting though.
