Author: Subject: Megasquirt – to use EDIS or not
Duncan_P
posted on 8/1/09 at 03:43 PM Reply With Quote
I originally ordered up my Megasquirt kit with extra coil drivers so I could drive the coils directly, but with my build dragging on and on I’m now beginning to wonder if using EDIS would be a simpler solution. Certainly after looking at the changes needed to the standard Megasquirt to drive the coils directly EDIS does seem simpler.
To give you some background, the Megasquirt has been partially assembled but none of the modifications needed for direct coil driving have been made and hopefully when its finished it will be running the Zetec engine in the MK.
So my question is, is it worth persevering with direct coil drive or scrapping that idea and switching to using an EDIS module.
[Edited on 8/1/09 by Duncan_P]
scutter
posted on 8/1/09 at 04:38 PM Reply With Quote
The Edis gives a nice safety net of Limp home mode for Ignition, that's why I used it.
ATB Dan.
Jenko
posted on 8/1/09 at 04:40 PM Reply With Quote
I can help with this one :-)
I went through exactly the same process, started with coil drivers, then found the set up a real nightmare - you have to play around in software with dwell times, etc, etc...Also managed to burn them out quickly.
EDIS is tried and tested, very reliable, no set up required, nice and neat....Just make sure the interal mods to MS are the correct ones.....
Best of luck...
MY BLOG - http://westfieldv8.blogspot.co.uk/
GeoffT
posted on 8/1/09 at 05:17 PM Reply With Quote
Another vote for EDIS, if it's getting a crank signal, it'll always get you home. Why do a load of mods to make things less reliable...?
COREdevelopments
posted on 8/1/09 at 06:05 PM Reply With Quote
glad someone asked this as i was wondering the same thing. i have megajolt on atm but will be changing to t/b's soon so think it will be easier to keep the edis as its already wired in.
also where can i get a decent megasquirt ecu for decent money?
atb
Rob
rayward
posted on 8/1/09 at 06:20 PM Reply With Quote
deffo use the EDIS
Ray
t16turbotone
posted on 8/1/09 at 06:23 PM Reply With Quote
edis......got my vote for all the reasons mentioned...works a treat!!
matnrach
posted on 8/1/09 at 06:46 PM Reply With Quote
I originally had MJLJ and converted to Megasquirt and kept the EDIS.
I also kept all my MJ loom so the Megasquirt loom was much easier and quicker to make.
EDIS is pretty bullet proof and I would use it again.
The only issue is that you can't have an ignition cut as a limiter but if you retard the spark to 0 as per MJ then this works perfectly.
[Edited on 8/1/09 by matnrach]
Duncan_P
posted on 8/1/09 at 07:02 PM Reply With Quote
Thanks for all the responces, very much apreciated.
Well you seem to have confirmed what I was begining to think.
RE:
Well it seems to be a running theme of my build to overcomplicate things as much as possible
But in an effort to finally finish im begining to junk most of these idea
Steve Lovelock
posted on 8/1/09 at 08:16 PM Reply With Quote
Well I built my own system with the drivers for the coil and it was not troublesome. It works well. Have never touched the dwell angle or any of that stuff and the car drives beautifully.
Lars
posted on 8/1/09 at 08:30 PM Reply With Quote
Another vote for EDIS.
VEry easy to set up
turboben
posted on 8/1/09 at 09:27 PM Reply With Quote
If your running normally aspirated go with the edis because of the above reasons(limp home etc). But when I used it with about 17psi boost it just carried on revving with the ignition backed to 0. Messing about with direct drivers now.
paulf
posted on 8/1/09 at 10:55 PM Reply With Quote
With edis you could implement a hard cut in the same way as megajolt does it by switching a resistor across the coil windings.I am using both systems at present but with the megajolt providing ignition , rev limiter and shift lights and the tacho signal to the megasquirt for just the fuel , but intend to change to megasquirt and edis only over the winter.
Paul
