RichB
posted on 14/1/09 at 10:07 PM |
Type 9 to electronic speedo
Hi all
This may be another of my noddy questions but I can't seem to find the answer anywhere. I have decided to use an electronic speedo and so I
presume I need to blank off the fittings in the 'box where the speedo drive gear and cable would fit. I bought the 'box off ebay and it
didn't have the drive gear fitted.
Do I just need this part from Burton (5th from bottom)
"PLUG - SPEEDO GEAR RETAINER" GBT9541 ?
Rich
dave1888
posted on 14/1/09 at 10:23 PM |
Thats the part that fits from the underside (opposite of cable) and holds the gear in. Does that make sense
RichB
posted on 14/1/09 at 10:59 PM |
That's what I thought. Without it the drivegear would be exposed, right? What can I use to plug up the hole where the cable fits?
[Edited on 14/1/09 by RichB]
jollygreengiant
posted on 14/1/09 at 11:29 PM |
A speedo gear. The 'O' ring (in the box) on the cable side seals on the gear.
robinj66
posted on 14/1/09 at 11:38 PM |
You can fit electronic senders in the type 9 gearboxes. I think 2.0 litre granada's had them. Burton also do them
[The link to the Burton site didn't work in my post so do a search there for "speedo" and see the first two items]
[Edited on 14/1/09 by robinj66]
flak monkey
posted on 15/1/09 at 07:45 AM |
Oil will leak out of the box if you dont plug the old speedo drive with something. I turned up some aluminium plugs to blank mine off.
Sera
http://www.motosera.com
NS Dev
posted on 15/1/09 at 09:48 AM |
second above comment.
get a sender from a 1988/1989 granada
NS Dev
posted on 15/1/09 at 09:49 AM |
either that or as above just use an old drive gear!
