Mr Whippy
posted on 21/1/09 at 02:06 PM |
Single brake disk rear axle
Out of curiosity if a disk brake was fitted to a diff which also had the handbrake function.
Would that pass the SVA/IVA/MOT? I was wondering if they tested both rear wheels together or just one at a time, which with that setup would not give
equal braking. Is this setup more prone to spinning? (as in whole car round a corner...)
ta
[Edited on 21/1/09 by Mr Whippy]
mangogrooveworkshop
posted on 21/1/09 at 02:21 PM |
I seem to remember alfas and lotus having inboard brakes however they where on the driveshafts after the diff. Me thinks this system of a single brake
unit is used in truck in a voith retarder system
Mr Whippy
posted on 21/1/09 at 02:39 PM |
yeah ta, jag gear has them inboard on each rear drive shaft, but I notice some BEC's appear to have a disk on the diff and was wondering is
thats all they have or is it just for the handbrake?
r1_pete
posted on 21/1/09 at 03:01 PM |
sonds dodgy, and a good way of accelerating the wear on the diff, and if that breaks - no brakes.
[Edited on 21/1/09 by r1_pete]
mcerd1
posted on 21/1/09 at 03:18 PM |
landrovers have one parking brake on the back of the gearbox
the drums / discs at the wheels don't have any handbrake
[Edited on 21/1/09 by mcerd1]
posted on 21/1/09 at 03:20 PM |
Whip you're sure asking a host of BEC type questions of late
yellow melos
posted on 21/1/09 at 05:11 PM |
They check the read brakes and hand brake independently ( well they are ment to ) and then a balance test on both sides.
posted on 21/1/09 at 07:07 PM |
It is called a transmision brake -- they were used service brakes on car up until the mid 1920s, pretty sure they are no longer legal as service
brakes. --- ask anyone who has driven a car from the 1920s they will tell you they are nasty horrible things.
As parking brakes they have been used by Jeep, Land-Rover and a few other 4x4 manufacturers.
A transmision handbrake is normally tested the old fashioned way with a Tapley meter as they can't properly be tested on rollers.
[Edited on 21/1/09 by britishtrident]
Mr Whippy
posted on 22/1/09 at 08:04 AM |
cheers didn't think it was road legal
johnston
posted on 22/1/09 at 09:27 AM |
I was reading somewhere that the mk2 rally brigade had started getting around the handbrake at mot problem by,
Fitting a disc and cable caliper from a mountain bike between the prop and diff flange. Havent seen it done so dunno if its 100% cosher or if it will
work for sva. But if linked into the hydraulic lever and who's gonna know what effect it has. It ticks the mechanical brakes box.
Needless to say it probably drops off soon after mot anyway
posted on 22/1/09 at 11:59 AM |
They've been getting around the MOT problem for ages by just leaving the cables connected to the original handbrake.
johnston
posted on 22/1/09 at 03:33 PM |
No good but if you've not got handbraked calipers..
