Author: Subject: Polishing aluminium
Shamrock GS
posted on 23/1/09 at 09:49 PM Reply With Quote
Polishing aluminium
I have been trying to polish up my alloy sides but not getting a great finish. T cut or similar isn't bad but takes forever and still doesn't 'shine'.
What's the best way to produce a proper polished finish on aluminium? (Indeed - is it possible?)
G
Sun Tzu, The Art of War
SeaBass
posted on 23/1/09 at 09:52 PM Reply With Quote
I've had success with the following: Working through grades of wet and dry. Farecla G3 and water. Dry everything off then use Meguiars Metal NXT Metal Polysh (as it's spelt on the tub!) to finish off... It takes lots of time and effort. Everything you use turns black and your arms ache. It dulls with a couple of weeks if your using the car...
[Edited on 23/1/09 by SeaBass]
handyandy
posted on 23/1/09 at 09:55 PM Reply With Quote
hi, yes it is possible but takes a long time, lots of elbow grease, have you tried autosol? i imagine Tcut is being too abrasive & so giving you a dull finish.
andy.
my race bike frame was highly polished, could,ve used it as a mirror to have a shave.
posted on 23/1/09 at 09:57 PM Reply With Quote
If the metal is smooth but a bit tarnished then the Meguiars takes some beating.
A small hint - put a spoonful of plain flour in a dish. Put on the polish, let it dry then polish it off... at this point you're forever rubbing it off and getting black all over the cloth (but Megs is better than most). Dip a clean dry cloth into the flour and rub it over the metal, then rub it off with another clean cloth. Nice shiny metal!
posted on 23/1/09 at 10:00 PM Reply With Quote
I've used autosol with good effect. However as stated the oxide layer builds up blooming quickly unless you use clear coat on top.....
SeaBass
posted on 23/1/09 at 10:04 PM Reply With Quote
T cut is pretty abysmal stuff really... It's actually not particularly abrasive at all hence being sold in Halfrauds etc as safe for Joe Bloggs.
I tend to use Autosol for stainless and chromium plate it seems to lose it's 'cut' very quickly but is ideal for taking off stubborn corrosion/oxide layer.
tomgregory2000
posted on 23/1/09 at 10:13 PM Reply With Quote
vinyal wrap it with a funky design
Ive used autosol and it is good but 3M metal polish is much finer and gives a better shine but is much more hard work, i tried both on a s/s silincer, i did half and half and you can see the difference
thunderace
posted on 23/1/09 at 10:38 PM Reply With Quote
alloy if its very cold wont get shinny i do loads of polishing buy a alloy polishing kit from ebay its around £10 and comes with the bit to atach to your drill .
here is a pic of wheels i done and a bike frame you must use alu for final finish to be as good as this
Canada EH!
posted on 24/1/09 at 12:55 AM Reply With Quote
There is a pink jelly like polish sold at aircraft supply houses, works well, and the trick is the flour, it absorbs most of the polish to assist in removal of the black grung. I kept a Cessna 140 airplane polished and parked outside for two years before I gave up and painted it. If you don't have a warm garage to keep the polished car in, PAINT IT.
Shamrock GS
posted on 24/1/09 at 09:07 AM Reply With Quote
I am seduced by the idea of a polishing kit with powerdrill attachment. Stand by to be dazzled!
Thanks for the input
Gary
posted on 24/1/09 at 05:41 PM Reply With Quote
I use a cheap electric polisher and Meguires on my side panels. It would take at least an hour a side by hand ,now takes ten minutes.
